need help on 700r4 problems
Old Nov 27, 2003 | 07:14 PM
pearlpurple's Avatar
Is the 700r4 in my 85 Chev 1/2 ton the same as my 700r4 in my 93Z28??
I have a 1985 Chev 1/2 ton with 305 and a 4 speed auto which I am sure is 700r4
It knocks just like a bottom end engine knock. I know it is either in the tourque/tranny as I took the three tourque converter bolts out and started the engine up and no knock at all. I am also sure it isn't bottom end because I have been driving it like this for 4 mnths and engine has decent oil psi and runs great. I also have revved the heck out of the engine a time or two as I thought it was bottom end, motor is fine.
Other info:
- once warmed up (hot)very little knock.
- knocks at idle in neutral and in gear but with some throttle (in gear)it goes away
- knocks both reverse and forward
- knock is much worse upon cold start
- knock sounds like it coming out of tourque converter
what could I have going here??
Old Nov 28, 2003 | 03:26 PM
someone must have an idea??
Old Nov 28, 2003 | 04:52 PM
12SCNDZ's Avatar
Re: need help on 700r4 problems
Other info:
The transmissions are similar, but not the same.
It's possible the noise your hearing is a cracked converter hub. The transmission pump can make some odd noises, too, but if it's still operating OK, then I'd lean toward the converter hub.
Frank
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Jan 30, 2015 09:21 PM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
