need to get rid of ses light
Old May 14, 2005 | 01:25 PM
steves97z28's Avatar
i want to clear my ses light, and see what it comes back on for(switched sims from one side to the other, now have no activity code for both) can i just unhook the battery, or do i have to unplug the pcm.
Old May 14, 2005 | 03:15 PM
Z06Z28's Avatar
Re: need to get rid of ses light
unhook battery and hang out for about 15minutes or you can walk back out to the garage in a half hour. It will reset. What are the codes you throwing? No activity to the rear 02's? Shed a lil more light...
Old May 14, 2005 | 03:19 PM
yes heres the story, a few weeks ago, my ses light came on, i went to check the code, no activity bank 1 sensor 2. finialy got to swapin it out for the passenger side to see if the code would follow. went back to autozone to check the code, and it said no activity for both. its never ending, wish i had left the car stock. im at my end of my ropes, i have no money to fix the car, and everytime i think i start to get ahead, something else gets ****ed up.
Old May 14, 2005 | 04:17 PM
You can clear the codes from the PCM simply by pulling the "PCM BAT" fuse for 30 seconds.... not need for any longer period of time. But if the problem is still there, the codes and the SES light will come back on. If the SES light is on, the problem is "active" and needs to be fixed to get rid of the light.
Is it possible a wiring problem burned out the first sim, and when you swapped them side to side you burned out the other one? A simple wiring problem would explain it.
Old May 14, 2005 | 04:45 PM
its just one sim, i guess cause i switched them with out clearing the original code(no activity bank 1, sensor2) that code was read when i pulled them the last time. i just went to autozone, pulled the code, and only got 2 codes for the bank 2 sensor 2. cleared them and then drove till it came back on, same thing. so its in the sensor that was originaly on the drivers side.
Old May 14, 2005 | 06:23 PM
moparman's Avatar
Well, what are the code numbers?
Old May 14, 2005 | 08:01 PM
p0160
Old May 14, 2005 | 09:15 PM
moparman's Avatar
You're on the right track with the O2 sensor. Specifically, that's the code for the passenger side after cat O2 sensor. I think Fred is on the right track, as wiring or a connector problem is most likely the cause.
Old May 14, 2005 | 09:20 PM
nope its a bad o2 sim, it was originaly on the driver side, and throw a code, swaped it to the other side to make sure.
Old May 14, 2005 | 09:34 PM
moparman's Avatar
Here's the code definitions: http://www.troublecodes.net/OBD2/Pcodes.shtml
Old May 15, 2005 | 12:23 AM
Problem is he's got two threads running on the same "sim" problem. In this one he claims he got codes for no activity on BOTH sides. In the other thread, he updates people and explains that he forgot to clear the codes before he switched the sensors, or he got two codes for the same sensor on ONE side, or some such.
That's the problems with scattergunning multiple posts on the same problem on multiple forums. Apparently he thinks we're stupid because we didn't know it was only a problem with one sensor, which we clearly would have known by reading his other thread on another forum.....
Next time I'll avoid his posts, because clearly we are both wasting out time trying to help him in this thread, when the problem was already solved in the other thread......
Old May 15, 2005 | 10:26 AM
moparman's Avatar
I didn't see the other thread.
Gtpguy
Jan 26, 2015 04:50 PM
k1996z28
Jan 21, 2015 07:22 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
