Need Fuel Pressure Gauge for Testing
Old Jun 5, 2010 | 05:33 AM
FastandBlue's Avatar
Alright, time to finally buy one myself. Should I just go to autozone or a parts store and buy one? Or do I need one specifically for GM vehicles? I've seen a few fuel pressure gauges (for testing, not permanent) that say they are for testing GM vehicles. Do I need to buy one of those or can I simply get any gas pressure gauge at a store? Thanks!
Old Jun 5, 2010 | 06:30 AM
The fuel pressure test gauge has to fit on a -4AN connector, and it has to have a device in the hose connector to depress the valve core in the Schrader valve when it is attached.
Old Jun 5, 2010 | 08:06 AM
OneShoe50's Avatar
I got mine at Auto Zone, works like a charm and it has additional adapters so I can even check Ford's with it (wow). Make the investment in good tools they last longer.
And I'm always real careful around gas, because gas = bad fire.
Old Jun 5, 2010 | 01:07 PM
Exactly what I needed to know. Now I can finally own my OWN pressure gauge. Lol!
Sounds like what I am looking for. I'll stop by sometime and see if I can nab one.
Lol, it sounds almost as if you are talking from experience there with the fire.
Old Jun 5, 2010 | 03:43 PM
SS RRR's Avatar
Autozone sells two types that I'm aware of. The basic gauge which is in the $40.00 range had to correct fitting for the Schrader. Unless you are going to use the gauge on different cars the basic one will do.
Old Jun 5, 2010 | 04:57 PM
96SSIndeed's Avatar
I got mine at oreilleys. When you walk in its usually on the wall right behind the counter.
Old Jun 5, 2010 | 08:03 PM
Sounds good. I will go by and pick one up either tonight or tomorrow, depending on how late I get back into town. But yeah, I would probably use it on different vehicles, so I might go with a more universal setup. Thanks guys, I appreciate it!
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Moshbmx1
Feb 17, 2015 10:51 AM
Gtpguy
Jan 26, 2015 04:50 PM
