Need to find TDC FAST!
Old Aug 11, 2009 | 04:31 PM
LsX iN fOx's Avatar
Ok I am led to beleive my opti is not on properly and my timing is way off. I purchased the car without an opti, waterpump, or crank pulley. I slid the new opti right on and pointed the rotor in the direction I beleived to be TDC. Apparently I was WRONG as the car was able to crank once, ran like crap, and I havent been able to get it going since.
Im going to purchase a piston stop. Now I know I stick it in to the #1 piston, rotate clockwise and when it hits thats TDC for one side. Where do I mark the crank pulley? Straight up?
Now I know I have to rotate the other way and mark it again when it hits again (again need to know where to mark it.) After that Im confised as to what to do....Do I go to the center of those two marks and thats my TRUE TDC???
I dont have a degree wheel nor know how to use one.
Also once I do aquire TDC, on the opti, where do I face the rotor? Do I have to remove the whole opti to do this or can I just take the front cover off and throw it back on with some sealent?
Old Aug 11, 2009 | 04:38 PM
RUDEDOG's Avatar
You don't have to worry about tdc. Just make sure you get the cam pin in the right slot on the opti. It's obvious which slot it go's in if you look at it. It's the one with the little slot on the end.http://shbox.com/1/opti_back.jpg
Old Aug 11, 2009 | 04:43 PM
LsX iN fOx's Avatar
Car is a 94, never pulled the timing cover off or anything. From what I read there are 3 ways to be wrong, the opti slid right on but a the rotor could have moved and wasnt in the right spot
Old Aug 11, 2009 | 04:47 PM
RUDEDOG's Avatar
Ok. Now that we know you have a 94 (might want to make a sig) You line up the master splines. Same deal. You don't have to find tdc. Look at this. http://shbox.com/1/93-94_opti.jpg
Old Aug 11, 2009 | 04:55 PM
LsX iN fOx's Avatar
Thats the thing thats killing me, I did exactly that and the opti slipped right on. Would the rotor in the opti moving have anything to do with it?
My car is exhibiting these exact symptoms
https://www.camaroz28.com/forums/sho...ng+opti+timing
Old Aug 11, 2009 | 05:01 PM
The keyways have to match and that's it. Did you notice the other thread you referred to, the guy had difficulty getting it right? If the opti is good and the keyways match, then it's going to run.
Old Aug 11, 2009 | 05:06 PM
LsX iN fOx's Avatar
Thats what I dont understand it slipped RIGHT ON. But yet, I have to floor it to get it to run, and it doesnt stay alive as soon as I let go. I got it running the other day it ran like it had a BAD miss. I shut it down, after trying to get it to crank a couple times after that I finally got her going and it idled great. I thought that was rather odd but dismissed it as the car hasn't ran in over a year and a half. Couple days later I go back and now this I don't know what the problem is. I mean it seems like the same symptoms but if it wasnt lined up it wouldnt have ran right?
Old Aug 11, 2009 | 05:07 PM
If it was off just a little, it might still run, but probably with no power. With a car that has not been run for that long, fuel injectors may be clogged, too.
Old Aug 11, 2009 | 05:09 PM
LsX iN fOx's Avatar
SO what exactly would be off? Im asking as to what my next step would be cause I cant even get it to turn over now. Do I have to remove the opti and slide it back on? Reposition the rotor? Im at a loss
Old Aug 11, 2009 | 05:12 PM
If you want to be sure, you'll have to remove the opti and check the indexing. Not saying it's your problem, just something you have to rule out.
Old Aug 11, 2009 | 05:16 PM
LsX iN fOx's Avatar
Man this is an absolute nightmare. I cant understand how it ran great idling, then as soon as it went into gear it dropped below 500RPM and almost died. And now I cant even get it to run at all
Old Aug 11, 2009 | 05:18 PM
Add a "signature" with basic info about your car - year, model, engine, tranny and any major mods. That way people can give you the correct info for your specific car.
Old Aug 11, 2009 | 05:23 PM
LsX iN fOx's Avatar
I think Im going to take the train over there and double check as to my wires being in the correct locations. I doubt very highly I screwed that up but then again hopefully its as easy as doing that
Old Aug 11, 2009 | 09:02 PM
LsX iN fOx's Avatar
Just got back. She fired right up I horribly crossed the wires. Never thought I'd make that mistake but there's a first for everything. Didn't mean to make everyone crazy just I try to prepare for the worst. I still have a small leak still on my water pump so I'm going to pull it off again and use RTV this time around and see how it holds. Thanks everyone for the fast responses!!!
Old Aug 12, 2009 | 05:37 AM
wrd1972's Avatar
If I had a dollar for every time I did that...
maybe2fast
Mar 16, 2015 09:45 AM
canbaufo
Feb 24, 2015 10:27 AM
maybe2fast
Feb 5, 2015 05:14 AM
birdblack
Dec 30, 2014 06:59 PM
Aneurysm
Jul 22, 2002 08:42 PM
