Need A Few Fast Answers
Old May 5, 2007 | 11:28 AM
turnin20s's Avatar
1. I searched, but turned up nothing. I need to know the torque specs on the rocker studs, mine are ARP 7/16" if that matters.
2. Whats the best way to set up a CC306 with Comp Pro Mags and Comp R lifters? I'm going to be using shoebox's method with #1 TDC then #6 TDC, but what should be the preload with the ARP 7/16 studs? I think I read about a 1/4 turn after there is drag on the pushrod, but please correct me if I'm wrong
3. Does the oil filter adapter get a gasket? I'm talking about the stock aluminum piece that bolts to the block that the oil filter screws onto.
Thanks in advance
Old May 5, 2007 | 03:08 PM
turnin20s's Avatar
Ok forget the rocker studs, but what do the rods get torqued to? I have them at 45 which is what the gen 1s are, but I just thought I'd double check.
Old May 5, 2007 | 06:05 PM
WS6T3RROR's Avatar
http://www.bfranker.badz28.com/fbody/torquespecs.htm
should handle your tq spec questions, and the adapter installs naked just like it came out.
Old May 5, 2007 | 09:05 PM
Thanks in advance
If you are using info from my site to set the lash, it tells how to set it for the Comp R's.
Nayr
Mar 3, 2023 08:34 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
cmsmith
Aug 9, 2015 07:30 PM
michaelzilinski
Jul 31, 2015 08:41 AM
