need expert advice before i throw in the towel!!
Old Jul 21, 2004 | 10:31 AM
MonkeyManZ28's Avatar
well i just had a new motor installed with the hot cam, ported heads, longtubes, and all the bolt ons. i picked it up and drove it for the first time in 7 LONG AGONIZING MONTHS. well it ran great when i picked it up, but in a matter of 8 to 9 hours the car is running like s****, missing like there is no tomorrow, won't idle, will start but will quickly die in a matter of 1-2 seconds. i was thinking that the car sat for 7 long months with only about a gallon or less of gas. i think whatts causing my problem is when it sat it developed crap in the gas tank and clogged my fuel filter. what kind of additive can i put in my tank to get rid of that crap. do u guys think this could be my problem? i really and hope not its not the opti, it has about 3000 miles on it, brand new plugs, wires, etc. what could my problem be?
thanks in advance
justin
Old Jul 21, 2004 | 10:34 AM
HBHRacing's Avatar
Re: need expert advice before i throw in the towel!!
7 months isn;t that bad.. filling up with good gas and maybe some injector cleaner and running it through should take care of that. I'm willing to bet it;s something to do with the install. do you get any codes out of it? what about burnt plug wires?
Old Jul 21, 2004 | 10:40 AM
the funny thing is that it was running great when i first picked it up and through yesterday it got worse and worse. no burnt wires at all i checked every single inch. the only codes i am getting is p 0336 crank sensor performance and p0135 o2 sensor. i heard that the crank sensor has no effect on the performance of the car only senses crank vibrations and the o2 code i had before this new motor but will be replacing that today
Old Jul 21, 2004 | 11:20 AM
ttt anyone else
Old Jul 21, 2004 | 11:54 AM
smoknta's Avatar
Bad O2 sensors can cause many problems. Mine went bad and it was dumping serios amounts of extra fuel in. Would barely run and was fouling plugs. I would change out both o2 sensors if i were you, especially if you are getting a code.
Old Jul 21, 2004 | 12:57 PM
dreamer1q's Avatar
Check the valve train....broken springs. Someone measured wrong???
jayblev95
Sep 26, 2015 09:44 PM
Cbr02
Aug 23, 2015 10:55 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Jul 17, 2015 02:47 PM
GT what?
Jul 14, 2015 10:17 PM
