Need to Drain Coolant Before TB Bypass?
Old Nov 22, 2004 | 02:43 PM
WestCoast96Z28's Avatar
Yes, I've done a search on the throttle body bypass and have looked at Shoebox's instructions. My only question is if I have to drain the coolant before disconnecting the lines. Per Shoebox's instructions, my 96 doesn't require the coupling hose...just bypass the TB and straight into the steam pipe.
From what I can see the TB is the highest point of where the coolant flows, so I expect some leakage, but not much. Is this a correct assumption or will this stuff just start spewing out as soon as I disconnect a hose?
Would it help to open the radiator to vent? My concern is that the opti is "conveniently" right below where the hoses are to be disconnected.
Let me know from you guys that have done this.
Old Nov 22, 2004 | 02:51 PM
17WITHaBIRD's Avatar
Re: Need to Drain Coolant Before TB Bypass?
i didnt need to drain mine. just be careful not to spill any on the opti, you can cover it with a rag.
Old Nov 22, 2004 | 02:55 PM
Birdman7389's Avatar
Yep, pull your rad cap to make sure its not under pressure, and stuff some rags or paper towels under the hoses. You should have minimal spillage.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
