need diagnosis of problem
The cars a 1995 camaro z28, heres the list of problems..
now for the story, my dad was driving the car and noticed it was really overheating (but never dangerously) so he let it cool down for 30 minutes, then dropped the top and turned the heater on high and inched it to firestone to get looked at. they said that the water pump needed to be replaced. my dad didn't trust firestone so he took it to another mechanic and the mechanic said that the thermostat needed to be replaced.. after fixing the thermostat he said he found out that that a cylinder head was bent or cracked and it was probably caused by the car dangerously overheating for 30-40 minutes (im positive this never happened) and he wants 2 grand to fix it, so i just really need some more experienced opinions on this so if you can offer any thanks
also.. the car runs perfectly fine except for the problems i mentioned, no weird sounds or anything
the car under revs, like in 3rd gear at 40mph it should be at 3000rpm instead its at 2500rpm, its the same with all gears
at idle it revs at 1500rpm even after being warmed up
car overheating
(the under reving and idling at 1500rpm was happening before the car ever overheated)
car overheating
Re: need diagnosis of problem
If you have a warped head, you'll either have coolant being consumed through the combustion chambers (white smoke out the tail pipe), coolant in the oil (oil looks like a milkshake) or a small coolant leak though the combustion chambers resulting in a slow consumption of coolant and you need to top off the radiator. Do you have any of these symptoms?
Originally Posted by siodine-
does anyone know what the problem could be
2.73 in place of 3.23 would account for the 20% difference. Or 3.42 instead of 4.10. That's pretty easy to check.
An improperly calibrated tach could give the same results.
