need cam help!!
Old Dec 7, 2004 | 04:29 PM
95z28txn's Avatar
need cam help!!
i want to get a COMP Cams #CL12-214-4 with
Duration at .050: 253
Intake Valve Lift: 0.525
Exhaust Valve Lift: 0.525
Lobe Seperation: 110°
but it says i need a 3500 stall and i have a 2800 is that true i have an automatic and i will be driving on the street alot i was also looking at a smaller cam it also said i need a 10:5:1 cr
my car will have ported heads intake an underdrive pulley headers and an x-pipe what do you recomend
Old Dec 7, 2004 | 05:13 PM
SS MPSTR's Avatar
Re: need cam help!!
I think you need to do more research.
Old Dec 7, 2004 | 05:33 PM
95z28txn's Avatar
Re: need cam help!!
i know thats why i posted hear to learn from others
Old Dec 7, 2004 | 05:40 PM
madwolf's Avatar
Re: need cam help!!
That is a pretty big cam for every day street driving, but of course, driveability is a very relative term and depends on your own "tolerance" levels. What are your goals for the car? Do you know what your heads flow?
Old Dec 7, 2004 | 08:08 PM
97Z-M6's Avatar
Re: need cam help!!
Part Number 12-214-4
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS 305H-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.525 0.525
Duration At 0.006 Tappet Lift 305 305
Valve Timing At 0.006
Open Close
Intake 43 82
Exhaust 83 42
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 253 253
Lobe Lift 0.35 0.35
Lobe Separation 110
that cam is way to big for a daily driver, buy anyones standards for a 350CI motor, are you sure that that cam is for a lt1.
Old Dec 7, 2004 | 08:19 PM
Z95m6's Avatar
Re: need cam help!!
I'm not bothering to look but it sounds like thats a flat tappet cam.
Old Dec 7, 2004 | 09:15 PM
rskrause's Avatar
Moderator
Re: need cam help!!
That specifc cam is for a gen I SBC, not an LT1. It is a hydraulic flat tappet cam, not a roller. In any case, it is WAY too big for a street car with an automatic and a 350. It is a "single pattern" cam, the intake and exhaust durations are identical. LT1's don't like single pattern cams and need dual pattern cams, with a longer exhaust duration to compensate for the relatively weak exhaust flow of LT1 heads with a street exhaust system.
IOW, it is WAY off. How did you come up with this cam? Not a put down, but if you don't know much about this you will do far better sticking with on of the "regular" grinds that many have used sucessfully. Alternatively, if you don't have the time or interest to educate yourself about cams, you could buy a custom cam for ~$350-400. Take a look at the LT1 specific cams in Comps catalog to get an idea of the general specs that LT1's like.
Rich
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
