LS1 lid and Fast Toys Ram Air
Old Aug 17, 2004 | 07:34 PM
xxsaint69x's Avatar
Well i finally did it. The ultimate set up for my car.
It all started about 3 years ago when i put the LS1 lid on my car. I liked how everything worked/looked but the lid cracked so i decided to get rid of it completely.
Now 3 years later, ls1 lid is back, and this time i went all out and added the fast toys ram air as well (FTRA in LS1 world )
I must say its a damn tight fit under the hood but everything works awsome. Car does not run any hotter even though half of the ac condenor is covered by FTRA. LS1 guys love this set up and now i know why
here are some pics.
http://bellsouthpwp.net/x/x/xxsaint69x/Lid%20FTRA/
Marcin
Old Aug 17, 2004 | 07:53 PM
simple's Avatar
Re: LS1 lid and Fast Toys Ram Air
damnit, i was really hoping that was a stock hood
looks good man
Old Aug 17, 2004 | 08:23 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Thats pretty cool.
Old Aug 17, 2004 | 08:28 PM
Birdman7389's Avatar
Nice! Got a how-to???
Old Aug 17, 2004 | 09:23 PM
Z95m6's Avatar
why not just run the T/A or firebird LT1 ram air set up? I wouldn't want to block the radiator.
Old Aug 17, 2004 | 10:10 PM
94 TA TT2S's Avatar
I have a clean MTI lid with the SSRA .......Took a bit of work but once you get it aligned ....the 2 bolts pull everything down nice and snug......
Old Aug 17, 2004 | 10:13 PM
94 TA TT2S's Avatar
clear lid...hehe
Old Aug 17, 2004 | 10:14 PM
xxsaint69x's Avatar
got any pics of your setup?
Old Aug 17, 2004 | 10:17 PM
94 TA TT2S's Avatar
Not yet...Spent most of the night last night working on it...Did you use foam for the seals or rubber???
Old Aug 17, 2004 | 10:19 PM
94 TA TT2S's Avatar
I had to go to drastic measures to cover the holes for the factory radiator support and the Hole that holds the plastic piece that directs flow to the radiator.....Might go back and put that in...If I can.....But anyways.....I am gonna go back and use rubber to get a good airtight seal...
Old Aug 17, 2004 | 10:25 PM
94 TA TT2S's Avatar
Marcin.....Did you trim the lower airbox or something.....any reason you kept the stock radiator support?????
Old Aug 17, 2004 | 10:30 PM
Spinner's Avatar
He cut the stock radiator support to sit around the airbox.
Old Aug 17, 2004 | 10:32 PM
94 TA TT2S's Avatar
I was referring to the LS1 Lower Airbox....If he trimmed that or something....Mine bolts down With the 2 Outside LT1 bolt holes
Old Aug 17, 2004 | 10:41 PM
lt4 fd's Avatar
Any reason why you didnt go with the regular lt1 ram air setup... what did you have before the FTRA? Was there a noticable gain??
Old Aug 17, 2004 | 10:46 PM
xxsaint69x's Avatar
i had all the LT1 and LS1 sytems pertty much. FTRA/LID is the best combo.
I had to trim the ls1 airbox because LT1 UltraZ hood wont clear it. Then i trimed the LT1 radiator cover to make it all fit. I am going to make it look a little bit better when i have some more time. BTW i used ruberized weather striping foam from home depo
Marcin
