Need cam advice!
Old Oct 2, 2007 | 07:26 PM
9formula4's Avatar
Need cam advice!
OK so I am building another motor for my car and I have listened to MANY sound clips of LT1 cars with MANY different cams rangin from the 503 (which I currently am running) to the 847 and on up to the LE1,2,and 3 and also one AI setup. My problem is NONE of them are even closely lopey enough for my likings. Call me old school but I like the lopey, keep your foot on the gas to keep it running cams.
My question is is there any tips,hints,info, or advice you could give me to help me get a cam of that profile?
My new motor will be a forged 357 with P&Ped TFS 195 heads and a ported intake mani with 58mm TB. The CR on it will be ~11.1:1.
Thanks in advance.
Old Oct 2, 2007 | 08:32 PM
HardcoreRM125's Avatar
Custom ground solid roller then. Talk to Bret Bauer for what you want. SStrokerRace
Old Oct 2, 2007 | 09:01 PM
rskrause's Avatar
Moderator
Get a long duration cam with a narrow LSA and lope away. With a duration in the 240-250 range at 50 and an LSA of 110 it will lope plenty and may be kind of drivable with tuning, and enough gear and stall if it's an auto. Your CR is low though for a long duration cam.
Rich
Old Oct 2, 2007 | 10:21 PM
OldSStroker's Avatar
Bret (SStrokerAce) MIGHT not do a cam just for the lope if it won't also perform satisfactorily. "My car lopes like hell, but runs like $h!t." isn't much of a recommendation for a cam guy.
Anyhoo, there's a good chance Bret can do a cam with the mean, nasty lope at idle you want which will also make torque and power. That's probably more of a challenge than making a driveable cam. He's usually up for a challenge.
How about doing a 4-7 swap on the cam but not on the computer?
Old Oct 2, 2007 | 10:56 PM
CamaroRacing12's Avatar
gm847 has a nasty lope what is wrong with that one?
Old Oct 3, 2007 | 08:48 AM
9formula4's Avatar
Yeah I just realized I didn't add in the part where I explain I want a cam that will have a nasty lope but will also perform.
I will contact bret and see what he can do.
chuyz28
Apr 9, 2015 09:36 PM
jj_burchiel
Mar 5, 2015 07:05 AM
Killer94z
Jan 13, 2015 12:06 PM
1775.Z28
Jan 11, 2015 10:51 AM
chuyz28
Nov 25, 2014 11:14 PM
