Need 5 min of someones time to help with wire harness
97 LT1, need to know what color wire goes to what letter (abcd) on each of the coil plugs the coil (3wire) and the coil module (4wire). This should only take 5 mins or so to do. Thanks in advance. This aftermarket harness is giving me problems and the wire colors are not the same as stock so my manual is useless.
Re: Need 5 min of someones time to help with wire harness
Ignition module
A= pink
B= white
C= black
D= dark green
Coil
A= pink
B= dark green
I have a GM service manual for 97 and it only shows two wires on the coil (3 if you count the coild wire)
A= pink
B= white
C= black
D= dark green
Coil
A= pink
B= dark green
Jul 4, 2005 05:00 PM
CobraEatr
Jul 23, 2002 06:32 PM
