How tight should cam rataining bolts be?
Old Apr 25, 2005 | 03:24 AM
Kurt Crosbie's Avatar
I was trying to take those two bolts on the retainer for the cam off with a T27 torx bit today and the sumbitch broke. I went and bought another torx bit and it once again broke. I assume those bolts aren't supposed to be THAT tight. I figure, maybe 5lbs of torque?
Old Apr 25, 2005 | 04:05 AM
romoranger's Avatar
Re: How tight should cam rataining bolts be?
its like 100 inch pounds, so just a few foot pounds of torque will do it. and you need the t30 not t27
Old Apr 25, 2005 | 04:41 AM
bunker's Avatar
I believe it's like 8 lB, but stuff like that I think hand tight it better until you feel its good, I'd torque it and then try it by hand if you've got a feel for these things.
Old Apr 25, 2005 | 07:04 AM
that sheds some more light on the situation. I assure you that those bolts that are on there are T27, not T30. T30 didn't fit at all.
Old Apr 25, 2005 | 08:02 AM
105 lb. in. T30 is what fit mine.
Old Apr 25, 2005 | 08:23 AM
Is it even possible to have used different bolts than those that were made for the application?
Old Apr 25, 2005 | 08:54 AM
CamaroBoy96Z28's Avatar
Its possible. Anything's possible. T30 would be the correct size but if its a different size and working fine, I wouldnt worry too much about it. As long as the retainer is on there and staying on.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
