NASTY sound...like marbles in the intake, TAKE A LISTEN, Help please!
From my experience with blowing motors, you have one or more main bearings toasted; what happened was as evidence in your filter and the pics of the burnt rockers and pushrods is there was serious oil starvation meaning your oil pump needs replacing as well. You are better off with a complete rebuild because some passages are more then likely stuffed with shavings and the block will have to be dipped. It might be cheaper to buy a junkyard motor and rebuild the one you have with a complete disassembly. If you do not want to go that route and believe me when I say this dump about 2 quarts of kerosene in the motor and run it for about 2-5 minutes and immediately shut it down and drain the oil; repeat this twice and it should get 80-95% of the chips caught in your oil filter. I had to do this 2 times already and it saved my wallet. Also when the mechanic or yourself goes to replace the bearings; it should be pretty clean in there so you can see if there is other damage as well. Besides; that motor has serious oil burn and it will clean it out a little.
Damn I've never heard of that before...Kerosene?
With the sound of that knocking though, and oil starvation, might it be possible my lifters have gone south and need replacing? Maybe clogged with particles?
Also, if I'm going to tear it apart anyways, would it be wiser NOT to flush it w/ kerosene like you said, that way I can see what got torn up where and where it's deposited? Just a thought
Thanks for the suggestion!
Actually it *just dawned on me*, I've already got the intake/lifters/pushrods/valve covers off...REALLY don't want to put that all back on to clean it out...a hot tanking would do the same thing right? I know this way is a lot cheaper...but a hot tank would do the same?
I dont have much internal engine expertise so this is just an observation...
I just want to say that wow, this is the most interactive and helpful thread Ive ever seen on the board. Everything from movies to with sound, to step by step pictures to help analyze the problem and get it fixed. I'd just like to give all of you guys applause.
Good job guys. And Dave I hope the car gets back in shape soon with out taking too big a chunk out of your wallet.
Good job guys. And Dave I hope the car gets back in shape soon with out taking too big a chunk out of our wallet.
Shoebox: One hell of a page you have there. If you want any of the pics I've taken for your page there feel free man. That video is good too, it'll be a perfect example of a "whatever is wrong with my car" LOL
I'll be tearing some more stuff off tonight after work.
Not looking forward to dropping the tranny though, I just put a new clutch in about 600 miles ago
Just for ****s and giggles, I called up the dealer and asked them what I was looking at.
~$1500 LABOR for Remove/Replace the engine on this car.
$5932.74 + $325 core for the engine, does not include starter/hramonic balancer/water pump and something else.
For that price one would be better off buying a stout built block from a reputable company!
Just thought I'd throw that info out. No way I'm going that route though.
It's nice to be able to work on cars, look how much money we save!!!!!!!!!
I have listened to that clip a few times. I think you have a rod bearing that has opened up enough that the piston is striking the head. There is a hollow sound to it that tells me a piston skirt is getting hammered. Don't run it anymore, pull it apart. If you are lucky the crank can be turned under. If not, it will have to be spray welded or replaced.
My guess from a thousand miles away anyhow.
Let us know what you find.
Called every JY and repair shop and machine shop and used parts place around, only one place might have one, for $1500!
Had a semi-productive night. Post more pics when I have more energy as well.
I learned a valuable lesson. Don't bother cleaning up anti freeze until you're all done. Wasting time. If you have the front end up, let it down, jack up the back end, sit on the front end, get as much out as you can, THEN clean up the mess. I must have cleaned up that puddle 4 times tonight :livid:
Sometimes it didn't exactly spill onto the floor either
Yeah, it sucked mejor *****.
Got the fans out:
After some fighting, the radiator is out. PITA, because the AC sits on TOP of grooves in the radiator, along with an AC line. General pain in the *** kinda.
Some of the hoses removed, still got a few left:
All the hoses off the front, along with the coil, and some thing that I don't know what it was or did:
That is all. My picture monkey was active, but is going to bed now. More later if I'm not too lazy.
Yeah, it sucked mejor *****.Got the fans out:
How much does a replacement water pump go for?
What's that optispark conversion go for? What's it do?
I just got back from the Machine shop.
Here's the machining prices:
Torque Plate Bore/Hone ............................$100
Line Bore if wanted ...................................$125
Install Cam Bearings .................................$25
Clean & Check Rods ..................................$25 all
Resize Rod ................................................$1 0 ea.
Hot Tank / Magnaflux Block .......................$35
Grind Crank ...............................................$65
Polish Crank ..............................................$25
3* "multi-angle?" Valve Job .................... ..$75
Assemble Shortblock w/ 3 mos warranty ..$125
Assemble Longblock w/ 1 yr warranty ..... .$225
--(Includes headwork, new guides, paint block, valvejob etc.)
Forged rebuild kit ......................................$550
Estimated assembled longblock rebuild pan to intake...$1200
So, that's not bad at all IMO. He said that of course we'll have a better idea of what will need to be replaced when it's torn down. They'll check everything over etc. as well.
Now I'm starting to think "Well, since it's apart...roller rockers aren't *THAT* much" :idunno: LOL, I need to stop!
