Narrowing Down The Possibilities Concerning My Arcing Problem!
Old Jan 22, 2004 | 07:07 PM
TArider21's Avatar
Angry Narrowing Down The Possibilities Concerning My Arcing Problem!
Well, talked to Fastbird93, and he gave me a general idea on what is causing my problem. There is a constant arcing at the coil and car is hard to start, Fastbird said that it is loading up on fuel causing the arcing. Here's some info on my car: my O2 sensor readings are all over the place even after I put new O2s in about 4 months ago. Could this cause the computer to dump more fuel than necessary, also was considering a clogged catalytic converter, or maybe my ecm has gone haywire, and it's time for a new one, this would explain the bad O2 readings and hard starting. If I'm on the right track, please inform me! Forgot to ask: Could a bad alternator cause symptoms similar to the ones I've described?
DirtyDaveW
Mar 15, 2015 07:01 PM
MattFick
Feb 15, 2015 10:16 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
slothgrant
Aug 22, 2002 03:01 PM
Z28 97'
Aug 4, 2002 09:43 AM
