NA or FI ????
Old Jan 19, 2008 | 05:35 PM
  #16
FASTFATBOY's Avatar
Get a VRE or Golen Shortblock set up for boost
http://www.golenengineservice.com/ht...rt_blocks.html
VRE............
RE 383ci Racer Series Short Block
pic
Description:
Our 383ci LT1/4 Short Blocks are for the enthusiast that demands more from their engine. This engine can easily support 600rwhp in power adder applications with a shelf stock piston. Be sure to contact a member of the VRE staff for your specific application.
Specs:
* Compstar 3.750" Stroke 4340 Crankshaft
* Compstar 6.000" H-Beam Rods
* Mahle -5cc Flat Top Pistons
* Mahle Rings
* Clevite Rod Bearings
* Clevite Main Bearings
* Clevite Cam Bearings
* ARP Main Studs
* Balance Rotating Assembly
* Fully Machine Block w/ Deck Plates
* Blueprint and Assemble
Options:
* Fel-Pro Head Gaskets $39.99ea
* Cloyes Timing Set $90.99
* Comp Cams Camshaft $245.99
* BBK 58mm Throttle Body $309.99
* Piston Coating on Skirts and Tops $315
* ATI Harmonic Balancer $379.99
* ARP Head Studs $124.99
* Upgrade to Callies Dragonslayer Crankshaft $500
* Upgrade to Diamnd Pistons and Rings $250.00
Price:
* $3650.00 *No Block Core Required*
Bolt a set of LE1/2 or Ai heads, intake/cam package, stir in 10lbs of boost.....DONE.
David
Old Jan 19, 2008 | 05:42 PM
  #17
mdacton's Avatar
Plus all the odds and ends you need....It won't be as cheap as you think. As long as you realize it ahead of time you will be fine.
I built a el-cheapo engine....eagle rotating assym, $1500 heads about $1200 in the valve train. Cometics, machine work...did it as cheap as I could ( I'm on a limited budget) And it was not still cheap.
And I know it probly won't last either, I wish I would have done something else and spent more money
Old Jan 19, 2008 | 08:24 PM
  #18
xBaDaSs97z's Avatar
ughhhh lol all this money lol... i was lookin to spend around 10k total...guess its not possible ..... maybe ill just build a motor closer to 430-450 whp and worry about boltin the charger on later ..... so many variables to think about..... i just dont wanna make a mistake its alot of money to be messin aorund with
Old Jan 19, 2008 | 08:31 PM
  #19
mdacton's Avatar
a good bottom and nice heads/cam is more than enough power for a street car. you should be 400 easy with a M6
Old Jan 19, 2008 | 09:11 PM
  #20
FASTFATBOY's Avatar
You CAN do it for that, but you will have to shop around and buy ALL used stuff.
See ya in the for sale section
David
Old Jan 20, 2008 | 12:25 AM
  #21
rskrause's Avatar
Moderator
$7,500 is a good budget for a low boost setup.
Rich
Old Jan 20, 2008 | 12:44 AM
  #22
reamo04's Avatar
VRE............
pic
Description:
Specs:
* Mahle Rings
* ARP Main Studs
Options:
Price:
David
you dont even have to go that crazy for a shortblock
My shortblock will be about 1500 and it'll hold up to boost.
I can get a forged shortblock locally thats going to be the same as that VRE for 2k.....
Check your local machine shops for prices
plan on about 2500 for a good topend
If you are going boost...theres no need to immediately upgrade the top end. except the cam.
Old Jan 20, 2008 | 02:53 AM
  #23
rskrause's Avatar
Moderator
We were talking about a longblock/complete engine (at least I was).
Rich
