Mysterious oil leaking problem
Old May 7, 2003 | 05:52 PM
WhiteThunderZ28's Avatar
Angry Mysterious oil leaking problem
On my 1994 Z28 I have an oil leak and its not coming from the Intake Manifold at all, it clean and dry.
But the bottom part of my opti has oil on it and the oil goes completely down the front of the engine. Possibly opti seal not put on right?
Anybody have any ideas where else this oil leak could be coming from?
All help is needed.
Old May 7, 2003 | 06:40 PM
94 CAMRO Z28's Avatar
I would think the opti seal more than likely. Also just a thought but my timing cover was leaking and when I did the cam swap I found out that the bolts on the bottom half of the timing cover were so loose I probably could have taken them off by hand.
Aaron
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
96z
Sep 5, 2002 07:53 PM
