Are my rocker arms to tight??
Old Oct 5, 2005 | 02:53 PM
rsjay's Avatar
I friend installed crane gold 1.6 roller rockers, hotcam, and new timing chain in my 1994 Lt1 Camaro. The car is not running like it should be. Idling around 500 rpm's. I thought it may have been my custom tune with PCMforless but he said it was just a standard tune. It appears to be flooding but my fuel pressue is at 42 PSI. I've posted here before thinking it was a fuel problem but now I am thinking maybe the rockers are too tight because there is no power in the car and when I rev it up it doesn't seem like it has much kick and is holding back. Any suggestions? If my rockers are too tight how do you tighten them properly?
Old Oct 5, 2005 | 03:45 PM
93black-ta's Avatar
Re: Are my rocker arms to tight??
it could be very possible its overtightend rockers. did you upgrade your springs also? i belive the hotcam is pretty big for stock springs.
how to adjust rockers, you can thank shoebox
Old Oct 5, 2005 | 04:02 PM
rsjay's Avatar
I can't remember if the springs were replaced or night. It was done back in the spring. I will check with my buddy. If they were stock would that cause a problem with the hotcam and 1.6 RR?
Old Oct 5, 2005 | 04:16 PM
RE AND CHERYL's Avatar
Stock springs are only good to about .500 lift. I really hope you aren't still running the stock springs as the hot cam with 1.6RRs makes .525 lift.
Old Oct 5, 2005 | 05:14 PM
rsjay's Avatar
I confirmed I did install new springs with the hotcam kit. They are good for over 600 lift.
Old Oct 5, 2005 | 05:25 PM
Evil Eric's Avatar
what brand/type of springs are they?
Old Oct 6, 2005 | 04:12 PM
rsjay's Avatar
They are GM I believe that came with the hotcam.
Wart Hog
Sep 8, 2015 05:53 AM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
94Form
Jul 17, 2015 10:56 PM
