My Opti Vent Tubes not hooked up....?
Old Aug 20, 2006 | 05:51 PM
97BBlackZ's Avatar
Well I'm in the middle of changing my opti and there really isnt any vent tubes coming off the damn thing.
Could this cause a problem? The only hose that is coming off is a black one about 5 inch wide that is connected to the black plastic side of the opti and is just dangling there. And where it suppose to go into the elbow the blue peice has a stopper on it and is just sitting there.
Would this cause a problem? Specially with the one that i'm having? ( Missing bog down. bearly drive ect.)
Anywho know where i can get the hoses for them and all attachments if there is any?
Old Aug 20, 2006 | 05:55 PM
JimboManJones's Avatar
Re: My Opti Vent Tubes not hooked up....?
Might cause a vaccum leak.
Poke around on www.shbox.com for awhile, you should find everything you need there.
Old Aug 20, 2006 | 05:56 PM
OBE1 95Z28's Avatar
From Shoebox's site:
http://shbox.com/1/opti_vacuum_harness.jpg
http://shbox.com/1/opti_vacuum_hose.jpg
12555323 $11.58
Old Aug 20, 2006 | 05:57 PM
97BBlackZ's Avatar
Do you think it could allow water/moisture into the opti and ruin it?
Old Aug 20, 2006 | 05:59 PM
97BBlackZ's Avatar
sweet thanks guys. Can i get this at autozone or should i go to a dealership?
Old Aug 20, 2006 | 06:03 PM
OBE1 95Z28's Avatar
Without any hoses connected you aren't creating any air flow through the opti to vent it so it will act like a non-vented opti.
Old Aug 20, 2006 | 06:04 PM
OBE1 95Z28's Avatar
Dealer only item or any of the discount GM sources like Dal, Jason Cromer, etc.
HectorM52
Jul 30, 2017 11:46 AM
jmadoll
May 27, 2015 07:13 PM
*Emilia*
May 13, 2015 09:05 AM
Injuneer
Dec 15, 2014 09:36 AM
