My next mods?
Old Apr 20, 2006 | 05:34 PM
cg4743's Avatar
My next mods?
Well I'm about to undertake a major weekend starting on the 28th. I will finally have my Hooker LT's in and it's time to install. My goal is by Monday morning to have installed, Headers and exhaust, A ported intake with new 50# injectors, a new Pcm from MadZ, and a PHR, TA, LCA w/relocation brackets, Shocks, Rear sway bar and a driveshaft all from Spohn. Also have new MSD plug wires and plugs. I'll have a friend helping most of the time so maybe we will get it done. My goal it to improve my 60' from 1..89 to a 1.7 and to get into the high 7's in the 1/8. My curent best is in my sig. Should I be able to reach my goal? I can't believe that I'm already trying to plan my next steps and I haven't finished this one yet. Should my next steps be heads and cam? If so, I up for suggestions and what kind of gains could I see? I know that everyone has different opinions, but that's why I love this site, I can't believe how much I've learned from reading all the post. I spend too much time reading on this site.
Old Apr 21, 2006 | 11:06 AM
2000GTP's Avatar
Re: My next mods?
That is alot of stuff to install by Monday, it is possible I guess if you have a helper. I would say that with your mods in sig and what you plan on installing soon, you should be able to hit your goal times.
Old Apr 21, 2006 | 11:25 AM
robwin95z's Avatar
Re: My next mods?
seriously.............do you know what your about to get into with the header install? it's easy but time consuming.
Old Apr 21, 2006 | 11:30 AM
94EvilZ28's Avatar
Re: My next mods?
Man...the hookers arent that bad...I just did mine Last september...they go up from the bottom...and the back bolts are a bitch...Good luck...I think you can get all that done...I got my headers in with a helper in only a few hours...maybe 2-3...and It was my first time...just keep busy and have your helper kickin *** and you should make it by that time.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Jul 7, 2015 08:19 AM
