my lt1 is leaking coolant everywhere
Old Aug 19, 2005 | 04:02 AM
MENEGRANDE's Avatar
OK,
my car is leaking coolant everywhere. it leaks right below the radiator cap, and behind the passenger side header. anybody got an idea of whats going on?
thanks
Old Aug 19, 2005 | 04:23 AM
ChevyTuffD.A.'s Avatar
Re: my lt1 is leaking coolant everywhere
Well......to me it sounds like coolant is leaking from the places u described. There isnt really much we can do accept just tell u to look for exactly where its coming from. There is prolly a crack in the hose or something.
Old Aug 19, 2005 | 08:32 AM
2000GTP's Avatar
I just fixed a coolant leak similar to yours, it was leaking from the radiator cap. The previous owner installed a K-mart radiator cap and it obviously wasn't doing the trick so I installed a brand new GM cap and problem solved. Also, for the passenger side leak, there are heater hoses that run around that area so it could possibly be that. Give it a good inspection and hopefully you will find your leak/leaks.
Old Aug 19, 2005 | 08:37 AM
69gto96z's Avatar
Could be a cracked head or blown head gasket leaking at the back of the motor, but I would check hoses first.
calaban
May 18, 2020 06:43 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
dansam
Jul 20, 2002 01:10 PM
