my heads are back from lloyd!!!
Old Dec 17, 2003 | 10:56 AM
  #46
BigJustinZ28's Avatar
lloyd is a very nice guy , i emailed him about porting my lt4's and he flat out told me that altho he would have charged me very little to port them , on my car the improvement would only be a few tenth's and that money would be better spent on other parts of my car to drop my times. When I reach the point tho that I either have money to burn or the heads need to come off im gonna mail those heads off to lloyd .
Old Dec 17, 2003 | 11:46 AM
  #47
whontime's Avatar
Originally posted by RallyRed701/2
so how much did you end up spending whontime? if you dont mind me asking...?
what are the max flow #'s you could get just out of p&p and a valve job with stock valves? cause im on a bit of a budget, and am just wondering how big the difference is between stock valves and larger ones.... and im talking numbers...
I don't really know what the max flow would be using stock valves. You would need to ask someone like Lloyd about that. In my case the valves were not that expensive because I used a cheaper brand. I think it would be best to get the valves done if you are going to have the heads ported. As for what I paid, it was $1,000 and no cores.
Old Dec 17, 2003 | 05:42 PM
  #48
ImpySS's Avatar
I am currently having a set of iron heads ported by Lloyd and discussed this topic with him. I opted for stock valves backcut for my application, but I am looking for street manners and have a small cam (502). He told me that a set of 2.0 1.56 will generally flow 10-15 cfm more than stock valves depending on the brand, Ferrera being the best. He also said, at higher lifts, a stock valve with the proper backcut can flow about the same.
Old Dec 18, 2003 | 06:21 PM
  #49
besz28's Avatar
thanks guys iam really happy.
Old Dec 18, 2003 | 06:29 PM
  #50
PoorMan's Avatar
$1200 would cover porting the heads, Ferrera 2.00/1.56 valves, Comp 987 springs, 10 degree retainers, locks, locators, seals, machining for seals and locators, milling, cleaning and assembly.
That's exactly what he did for me. Pics of heads before/after and flow number chart and graphs in sig.
Jeff D.
Old Dec 18, 2003 | 06:59 PM
  #51
Brent94Z's Avatar
Super Moderator
Just an observation but for the price he is charging he probably isn't flowing each and every port. I got the impression from an earlier message that he may not even have a flow bench? If that is true he is probaby porting them based on vast experience and the machine shop is flowing just one port. That could be the reason for the variances between you guys but on average they are probably all very close? Just a guess Either way, as has been mentioned, the proof is in how the car runs and his heads seem to do very well so who cares what they flow
FWIW, I just sold a set of LT1 heads. These heads were used on a LT1 Camaro that ran 120 mph N/A. While the flow numbers do not appear as impressive as what you guys are posting, they do perform well. Only one set of ports was flowed and here are the numbers...
Lift Exhaust Intake
.200 60 105
.300 76 192
.400 88 231
.500 93 258
.600 124 270
.700 180 270
As you can see, the numbers aren't as good as the ones being posted here but the heads work good... there is more to a good set of heads than just high flow numbers The exhaust numbers don't look right but that's what they the guy gave me so who knows.
Anyway, just wanted to point out that Llyod isn't using a CNC machine so they will all not be the same but on average they are probably all very close
Old Dec 18, 2003 | 07:02 PM
  #52
Fastbird93's Avatar
The biggest numbers to look at are going to be your mid lift. The valve spends more time there than anything, and the higher the mid lift numbers the more total air you're going to flow.
Old Dec 18, 2003 | 07:55 PM
  #53
97 RedSS's Avatar
Yup..he does have a Superflow flowbench
He grinds on 1 port then he matches that will all the other ones..Im sure the ports are within 5cfm of each other..
Cody
Old Dec 18, 2003 | 08:49 PM
  #54
97Z-M6's Avatar
yep i was at his shop a week ago and he does have a flow bench.
seen it with my own 2 eyes.
Old Dec 18, 2003 | 10:09 PM
  #55
J's 82's Avatar
Just saw this and figured I would add my .02.. my heads are currently with Lloyd and he just sent me the flow numbers..
.1 64/49
.2 134/105
.3 188/147
.4 232/168
.5 262/181
.6 269.8/187.8
total cost to me is 1000.. that was the porting, larger Rev valves, guideplates, 7/16in studs. and double springs..
these will get bumped along by a 230/236 and 1.6 pro-magnums..
His customer service alone was worth it.. can't say enough good things about his rapid responses to questions..
Old Dec 18, 2003 | 10:18 PM
  #56
rage366's Avatar
it's not all about max flow...
Old Dec 19, 2003 | 05:41 AM
  #57
ImportsRsloths's Avatar
Lift Exhaust Intake
.200 60 105
.300 76 192
.400 88 231
.500 93 258
.600 124 270
.700 180 270
Something doesnt sound right! This car have N20 or what??? 120 mph
Old Dec 19, 2003 | 05:58 AM
  #58
simple's Avatar
a good matched camshaft and it is very possible, i think those numbers are quite respectable compared to some of the big name companies
Old Dec 19, 2003 | 07:09 PM
  #59
besz28's Avatar
thanks for the replies time for me to put them on along with xe cam
Old Dec 20, 2003 | 03:41 PM
  #60
jonaddis84's Avatar
Just cuz its an LT1 doesnt mean its a 350, Im not sure but it very well could be a 383 or something close, just a speculation though. 120 traps are very doable with the right gears and cam
