my heads are back from lloyd!!!
Old Dec 16, 2003 | 05:23 PM
besz28's Avatar
got my heads from lloyd got flow sheet with them they might as well be in another language because i do not know what they mean lt1 stock intake 216.6 after 271.9 stock exhaust 156.4 after 194.2 those were max cfm so after lloyd did his magic the heads were 271.9intake 194.2exhaust what does this mean they look georgeous.... thanks
Old Dec 16, 2003 | 05:29 PM
Fastbird93's Avatar
The sheet should be broken down into various lifts of .100, .200, .300, .400, .450, .500, .550, .600 and have corresponding before and after flow numbers for each.
Basically, each lift number is how high the valve is lifted per se, and how much the head flows at that given point.
How were the mid lift numbers, from about .400 to .550???
Old Dec 16, 2003 | 05:32 PM
besz28's Avatar
400 236.1 154.5 4500= 254.4 167.3 5000=265.3 177.4 5500=267.8 181.7 6000=270.9 189.9 6500=271.9 192.1
Old Dec 16, 2003 | 05:56 PM
Mr.Whitey's Avatar
Re: my heads are back from lloyd!!!
Originally posted by besz28
...the heads were 271.9intake 194.2exhaust what does this mean.... thanks
...it means that they flow more cfm than the ones he did for me.
Old Dec 16, 2003 | 06:05 PM
GT40MkI's Avatar
Re: Re: my heads are back from lloyd!!!
hes getting better
Old Dec 16, 2003 | 06:09 PM
Mr.Whitey's Avatar
He must have learned something...I got 265.3 and 191.7 max CFM and that was less than 6 months ago.
Old Dec 16, 2003 | 06:20 PM
ImportsRsloths's Avatar
Yep, I think he learned a new "trick"..... What all did you have done to the heads?
Old Dec 16, 2003 | 06:31 PM
ibanez6rg's Avatar
Nice. Hopefully he'll be getting mine soon.
Old Dec 16, 2003 | 06:35 PM
Mr.Whitey's Avatar
P&P w/ stock valves
Old Dec 16, 2003 | 06:46 PM
Chris 96 WS6's Avatar
Interesting. I have the bigger valves and while he got 283 intake I am still just at 191 exhaust....looks like he learned something on the exhaust side to me.
Old Dec 16, 2003 | 07:09 PM
besz28's Avatar
i got the 2.00/1.60 ferrara valves
Old Dec 16, 2003 | 07:11 PM
Mr.Whitey's Avatar
THANK YOU!! You just made me feel much better.
Old Dec 16, 2003 | 07:40 PM
bunker's Avatar
Don't worry guys, he listens to what you need & ports/valve job accordingly, Mr.Whitey you might have 265 peak flow but what is your flow in the lower numbers? if you have a descent sized cam you need bottom lift numbers, if you have an XE cam, lower lift numbers aren't as important anymore but more/less 400+ lift, so it all depends, you can have a head that flows 287cfm & make 380RWHP & a head that flow 250cfm & makes 405RWHP, mid/low lift numbers are most important, how about you guys post your actual flow sheets on here & we'll be able to tell how good the heads are.
Ps. besz28, you must have had 561 castings if you have 217cfm stock or just a good set? you have about 5cfm over most stock heads.
Old Dec 16, 2003 | 07:41 PM
FacelessZ's Avatar
You mean you sent money and heads to have Lloyd work them over and you don't even know what the flow #'s mean?
Old Dec 16, 2003 | 07:43 PM
besz28's Avatar
yep 1200 bucks worth!!!!!!
