are my headers leaking??
Old Jun 26, 2003 | 12:37 PM
TMDZ28's Avatar
are they?? i dont know how to check if it has a leak or not, all i know is it sounds like crap when i rev the engine. it's a TES edelbrock shorties btw. anybody can help me here?? thanks
Old Jun 26, 2003 | 12:53 PM
blown383's Avatar
You have you retoruqed the header bolts and checked the collectors to see if they leak? Look for blackish-brownish soot around your headers to see if they are leaking. Btw who installed your headers?
-B
Old Jun 26, 2003 | 02:17 PM
TMDZ28's Avatar
-B
i tighten the header bolts like 5 times already when the engine is cold. what is black brownish soot?? all i see that there's a white powder on my headers, is this normal?? thanks. i still dont know how to check for leaks
Old Jun 26, 2003 | 02:42 PM
llafro's Avatar
to check for leaks, let it get warmed up, and then CAREFULLY try to feel around the primary tubes for a blast of air. Watch where you put your fingers, or you will get burned on the hot tubes. If you can't get your fingers in, try using a piece of paper to feel for the blast of escaping air.
BRAD
Old Jun 26, 2003 | 03:12 PM
TMDZ28's Avatar
BRAD
sounds like a good idea, will the air coming out from the leak strong, or just a breeze??
Old Jun 26, 2003 | 03:34 PM
blown383's Avatar
Well the car willbe idling so it'll be a light...don't expect a cyclone to hit your fingers.
Brad - Did you sell off your stock heads?
-B
Old Jun 26, 2003 | 04:08 PM
TMDZ28's Avatar
-B
alright, i'll do that today. thanks
Old Jun 26, 2003 | 07:24 PM
black bandit's Avatar
I have the same headers (TES), same white stuff around the collecters, and the engine doesn't sound healthy...Lotsa popping, and turbulance...maybe its due to the high flow cat, and "slowmaster" muff, but I'd like some opinions as well...TTT
Midnight_Z
Feb 16, 2016 09:36 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
