My Head Flow #'s
Old Jan 21, 2005 | 10:49 AM
transamtom's Avatar
My Head Flow #'s
I just got back from the machine shop,I don't have a scanner so I will just list them. Mild porting with 1.94 intake 1.60 exhaust valves.
Do you think the CC306 would work good with my set up? my gears will be 3.73
lift Int Ext
100 61 \ 49.3
200 130.8 \ 89.9
300 185\128.2
400 217.2\ 149.2
500 242.4 \ 162.8
550 248.6 \ xxxxx no exhaust # on 1/2 lift
600 242.7\ 173
Old Jan 21, 2005 | 10:53 AM
Z95m6's Avatar
Re: My Head Flow #'s
they aren't too bad for running stock valves, the exhaust is a tad low. I guess how much did you pay for them will determine if you got a great deal.
Old Jan 21, 2005 | 11:24 AM
WS Sick's Avatar
Was it only porting or did they back-cut the valves any? If they didnt I would dissasemble the heads and have the valves back-cut it will ad a noticable flow improvement.
But I agree , good numbers for stock sized valves.
Old Jan 21, 2005 | 11:30 AM
transamtom's Avatar
Thanks I was happy when I seen the numbers.
Yes the valves were backcut.
Old Jan 21, 2005 | 11:34 AM
WS Sick's Avatar
Cool , what cam do you plan to use them with , and what shortblock?
Old Jan 21, 2005 | 11:43 AM
transamtom's Avatar
I think if I go with an off the shelf grind it will be the CC306,but I am going to call Comp cams later and see what they recomend.
The stock shortblock.
I am just doing H/C electric wp and gears right now.
Old Jan 21, 2005 | 04:16 PM
blkchevyz's Avatar
my ARE heads only flow about 10 cfm more then that. and im running mid 11s
oh and i would try futural motorsports for a cam, i was running the 306, then i put their cam in and gained about 2 mph
went from 115 to 117.5
the cam im running has less duration then the 306, but its close to 600 lift
Old Jan 21, 2005 | 04:37 PM
transamtom's Avatar
I will be happy with a low 12.
If it went faster I would be doing back flips.
Thanks for the heads up on the cam.
Old Jan 21, 2005 | 04:58 PM
Kraest's Avatar
Retired
I'd be curious about the exhaust numbers.
If those are true numbers, I'd expect to see very low 12s on motor with a nice bumpstick without a hassle.
Mike
Old Jan 22, 2005 | 06:51 PM
blkchevyz's Avatar
were the exhaust numbers with or without a pipe?
Old Jan 23, 2005 | 09:35 AM
transamtom's Avatar
I think they were with a pipe,my flow sheets are at a friends house so I cannot check them right now.
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
