My Eradispeeds CAN'T be warped!!!
Old Jun 10, 2003 | 03:04 AM
Luke 96 T/A's Avatar
So what would cause my car to shake as I apply the brakes???
I've tested stopping with my e-brake... it's smooth...
when I use the pedal though, the whole car shakes???
But not everytime!!
Could it be uneven brakepad wear??? My chipped rear wheel??
What about something like the ABS module malfunctioning?? (even though the ABS light doesn't come on???)
Thanks for the help!!!
Old Jun 10, 2003 | 03:47 AM
joeSS97's Avatar
Who says they cant be warped?I bet the front ones are.With the E-brake you are only using the rears.The front ones are more prone to warp because they do the majority of the stopping.
Old Jun 10, 2003 | 04:04 AM
I'm just really hoping they're not!! They have 10,000km on them, and went through the proper break-in procedure... and have never been used hard!!!!!
and they can't be turned.. but do have a gaurantee..
wouldn't they shake ALL the time if they were warped??
Old Jun 10, 2003 | 04:12 AM
joeSS97's Avatar
Do you feel the pedal pulsating when braking?Could also be a worn ball joint or tie rod end.
Old Jun 10, 2003 | 04:34 AM
I only feel the pulsing when I'm braking....
never any other time....
Old Jun 10, 2003 | 09:51 PM
Slamhound's Avatar
Can't be turned?!?! Even Cross drilled and slotted rotors can be turned.
Yes, your rotors are warped.
You need to look very closedly at the calipers. Before I upgraded to LS1 brakes my rotors warped every 10k mi. The slide bolts in the LT1 caliper bind WAY to easily. Get you rotors turned by someone who knows how to deal with drilled/slotted rotors. Replace your calipers. Even then make sure the slide bolts slide smoothly.
My $.02
Jon
Old Jun 11, 2003 | 02:45 AM
Humm.. I wonder if that's the case??
I should have mentioned, I've done the LS1 brake upgrade as well...
everything went smoothly...
Since these eradispeeds have a limited 'lifetime' warranty against warping, I should just get 'em checked out and exchanged.....
The vibrations only occur occasionally, which I why I was curious if the rotors actually were warped??..
Old Jun 11, 2003 | 02:49 AM
RobK's Avatar
Is it worse when you stop from highway speeds? I just went through this with stock LS1 rotors on my LT1. I've got the cheapo Autozone ones now--so far so good.
Old Jun 11, 2003 | 02:51 AM
Yeah... much worse
sure sounds like warpage, eh? ;-)
If I'm going 90mph, and slow a little, I usually shake quite a bit..
if I'm going 30mph sometimes I shake, sometimes it's smooth....
Old Jun 11, 2003 | 02:53 AM
RobK's Avatar
Lightbulb
All the signs of warped rotors--had the same symptoms here--sorry man.
FredM
Jul 20, 2015 08:53 AM
96LT1Fan
Feb 2, 2003 05:17 PM
stew w/00&92
Nov 19, 2002 12:24 AM
Curt (pres AAMC & ZAA)
Aug 1, 2002 12:41 AM
2000CamaroNX
Jul 29, 2002 10:05 AM
