My coolant temp sensor snap... What to do?
Old Nov 15, 2005 | 04:00 PM
97BBlackZ's Avatar
So the wire that connects to the end of the coolant temp sensor on the driver side of the block obviously didnt like being connected to it and just snaped right off!!!
Now what do i do!! I couldnt figure it out at 1st till finally i saw that the sensor was still in there but there was NO wires connected to the end of it!!
Please tell me that you can switch out the wire/sensor part without having to solder another peice of wire in or getting another wiring harness.. Cuz that would really suck.
Old Nov 15, 2005 | 04:50 PM
pricelessz28's Avatar
Re: My coolant temp sensor snap... What to do?
you can buy the sensors at autozone for $7.99. you have to drain the coolant and swap it in. just did the same thing on my 93 z28. good luck
Old Nov 15, 2005 | 05:44 PM
97BBlackZ's Avatar
Oo well its not the sensor that goes into the block its the sensor that goes into the sensor that goes into the block lol if that makes sense The one with the wire that connects to it. THe wire snaped away from that sensor
Old Nov 15, 2005 | 06:16 PM
yournamehere's Avatar
Don't drive the car until the sensor issue is settled.
My '96 has been parked since May because the sensor in
the drivers side head broke at expressway speeds and within
20-30 seconds a head gasket let go.
I'm currently looking into a rebuilt, stock LT1
Old Nov 15, 2005 | 10:32 PM
NeverEverSatisfied's Avatar
Which one broke... the one that sends to the computer or the one that sends to the gauge. Yes there are two (2) different coolant temperature senders on your vehicle.
Old Nov 15, 2005 | 11:05 PM
97BBlackZ's Avatar
Its the one that sends to the gauge. Driver side right between the 1st and 2nd spark plug. I've driven on it fine and didnt have a problem so far. Hell when we did my header install we broke the actual grey peice that goes into the block and drove it like that for 120 miles(had to get home).
But this time the wire to the back of the sensor just seemed to snap off from it.
Old Nov 15, 2005 | 11:38 PM
3gc's Avatar
3gc
Did the wire actually break or did the connector just break? You should be able to pick up the weatherpack connector at the dealer, or maybe even a parts store. You could either solder the new pigtail in or remove the wires from the old connector and put them in the new one.
Old Nov 16, 2005 | 02:33 AM
97BBlackZ's Avatar
The wires actually broke.
As for the head gasket thing.. How could it cause a head gasket to blow?? It just sends it to the gauge cluster right...?
Old Nov 16, 2005 | 10:22 PM
Wiring pigtail for ECT sensor in head for gauge:
GM p/n 12126458 or
AC-Delco #PT728
Old Nov 16, 2005 | 11:39 PM
HardcoreRM125's Avatar
I bought mine totalled nad rebuilt it. On mine the wire wasnt even in the connector.
Unplug the connector, take the wire, strip the very end of it, and put it in the B side ( I think ) of the connector. If you look at the connector real close, once its unplugged youll see a little A and B , but im pretty sure the wire goes in the B side of it, anyways, just stick it in there, and then pinch it in with needle nose pliers. It was so long ago that I did it that I dont even remember how ... I think you have to pull the plug end ( Which goes INTO the sensor ) OUT, like pull it through, then run the wire through the connector, into the plug end, crimp it down really well, put some anti corrosive electrical **** on it, and push it back into the connector. Then plug it in.
95_Z28/SS
May 20, 2015 01:23 PM
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
