My clutch went!!!
Old May 11, 2003 | 09:08 PM
my350f's Avatar
My clutch went!!!
My clutch went and i'm wondering what you guys think is a good moderatly priced aftermarket replacement?
Old May 11, 2003 | 09:41 PM
94 CAMRO Z28's Avatar
Im about to install the Spec stage 2, its good to 475hp and should drive mostly like the stock clutch. Retails for $450 but can be found for less.
Aaron
Old May 12, 2003 | 01:02 AM
fbird95's Avatar
I have heard good reports about the Spec Stage 2, and the SLP kits. Both are not outragiously priced either.
Old May 12, 2003 | 07:46 AM
IDOXLR8's Avatar
If you are going to due more mods in the future then I would recommend replacing the clutch once and buying a McLeod Street Twin. Another option would be to go with an RPS clutch.
Old May 12, 2003 | 08:35 AM
TedH's Avatar
If your car is stock I recommend an OEM clutch. If not, the Spec has had generally good results from what I have seen for budget minded and lightly modded cars. If you have lots of power you need a street twin. Do a few searches, add some common sense, call the manufacturers and check out their websites. Read the warranty statements, and make an informed decision.
Old May 12, 2003 | 08:58 AM
LT1derful's Avatar
I got the Spec 2 on a modded stock LT1 and I'm having no trouble with 1.9 60's on stock 3.42s in M6 car. And, it drives around town like a champ. I really like it, and recommend it to anyone with lightly modded stock car.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
