My Car won't start
Old Feb 15, 2009 | 03:35 PM
  #16
jtarp's Avatar
I did not get any spark
Do not acknowledge
Last edited by jtarp; Feb 15, 2009 at 03:47 PM. Reason: Tested wrong wire...mistake
Old Feb 15, 2009 | 03:42 PM
  #17
LaredoZ28's Avatar
to test spark unplug coil wire from the Opti and insert screwdriver or test light on to the end u pulled off the Opti. hold screwdriver close to a ground point. not touching. Have someone start car and if u see a blue arc u have spark.
Old Feb 15, 2009 | 03:43 PM
  #18
LaredoZ28's Avatar
I'd try a coil first. they are like 50-60 bux at the autoparts store. if still no spark the check the harness for a broken wire.
Old Feb 15, 2009 | 04:46 PM
  #19
jtarp's Avatar
I tested it correctly this time I believe lol. I got no spark. So I thought maybe the wire going from the coil to the opti was bad. I took the wire off and sure enough I got spark coming from the coil. I'm guessing this is still a valid way to test it? The only bad thing is, is that noone in my town sells the wire...figures
Old Feb 15, 2009 | 04:55 PM
  #20
LaredoZ28's Avatar
u should be able to use any wire to test the coil.
Here is a place that makes the wires that u can put over the valve cover. u can also get them from summit or jegs.
http://estore.websitepros.com/2120533/Detail.bok?no=8
Old Feb 15, 2009 | 05:04 PM
  #21
jtarp's Avatar
I know that I can buy a whole set, but I was wondering if I could buy just the one wire from the coil to the opti. I found one on summit but it is 25 bucks just for the one wire. Can you think of anywhere I could get one cheaper? I hope this will solve my problem.
http://store.summitracing.com/partde...5&autoview=sku
Old Feb 15, 2009 | 05:05 PM
  #22
LaredoZ28's Avatar
What year is ur car? is it the one in ur sig? I may be able to help.
Old Feb 15, 2009 | 06:36 PM
  #23
jtarp's Avatar
Yes, It is the one in my sig. Any help would be much appreciated.
Old Feb 28, 2009 | 01:10 PM
  #24
jtarp's Avatar
Ok I finally got a new coil and plug wires because mine have never been changed. I know the coil is good and that the wire from the coil to opti is good now. Still my car will not start. When I turn the key I can here the fuel pump prime and everything so I assume I should be getting fuel pressure to the rails? I've done all of the testing as mentioned in the "How to properly diagnose a bad opti" sticky. I got no AC voltage while trying to start the car. Yes, I checked it correctly. My DC voltage was 12 volts in the correct terminals. I have everything to change out the opti, but I was hoping it might be something smaller. I guess I'm just going to have to bite the bullet and change it out?
Old Mar 1, 2009 | 05:08 PM
  #25
jtarp's Avatar
I changed out everything and still my car won't start. I got a fuel pressure tester and checked for fuel pressure at the schrader valve. I turned the key and heard the fuel pump prime but I got a reading of "0" on the tester. What could be wrong? Oh, and still no spark either. Is this an ignition problem or what?
Old Mar 2, 2009 | 01:12 AM
  #26
ZMAN Z28's Avatar
A few years back, my car wouldn't start. It would turn over till I drained the battery. It was my coil wire. Put a new one on, and it fired right up.
ZMAN
Old Mar 2, 2009 | 03:11 PM
  #27
jtarp's Avatar
Thats what I was hoping my problem was at first. Could it possibly be the ICM. It is the only part I didn't replace.
Old Mar 3, 2009 | 04:41 PM
  #28
jtarp's Avatar
TTT. please help
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
