My car is running rich
Old Jan 14, 2004 | 03:37 PM
white97z/28's Avatar
ANyone know how to fix this problem, its nothing major, not effectiving driveabilty or nothing, i just wat it cured. It just puffs a little black smoke at high rpm. Can anyone tell me what to do to stop it?
Old Jan 14, 2004 | 04:18 PM
The stock LT1 programming tends to be "rich" on the top end, typically setting a target A/F ratio in the range of 11.7-11.9:1. That shouldn't be rich enough to produce black smoke, but the condition can be made worse by things which cause the PCM to incorrectly richen the mixture.... including things like exhaust leaks and misfires. Have you ever had the PCM scanned, particularly for long term fuel correction values, and O2 sensor readings at WOT?
cmdeshon
Dec 27, 2014 10:06 AM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
