my car is overheating??
Old Oct 28, 2007 | 07:51 PM
sabedra211's Avatar
Hey everyone i just recenlty finished replacing my distributor cap, plugs and wires and now my car is over heating??? the temp. went up so fast. in minutes pass the 260 degree. also my ABS inop came on ?? I put my air pump in backwards could this be the problem?? i did drain the coolant and water but i didnt bleed the cooling system? How do i do that? My fans kick on and everything. Also whats an Air Dam?? Thanks!D:
Old Oct 28, 2007 | 07:55 PM
camarozz95's Avatar
Yeah you MUST bleed the system after words you have air pockets in the system this is whats causing you to overheat so fast.
Old Oct 28, 2007 | 08:05 PM
JP95ZM6's Avatar
http://shbox.com/1/4th_gen_tech1.html
Start with How To's. Then get familiar with the rest of the site. It's a great start and will help you figure out the basics, and a lot more.
Old Oct 29, 2007 | 12:03 AM
sabedra211's Avatar
yesss my car is not overheating anymore!!! thanks u!
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
