97 z28 engine
Old Oct 28, 2007 | 04:09 PM
win98nogood's Avatar
97 z28 engine noise ( video ) :(
I have a 97 z28 w/ 180k miles, the motor i think is dying even thought it just ran a 14.1@97mph stock today 10/28/07
I have a friend that got hit from the rear on his 95 impala SS the engine has 38K miles on it. getting it for cheap complete, will I have any problems installing that into my car , I guess while the engine is out I will install new water pump and all new gaskets and possibly a cam kit any suggestions would be appriciated
I was going to sell the car but the body is mint along with under carage might as well just enjoy the car
Old Oct 28, 2007 | 04:17 PM
Mtxz453's Avatar
why do you think the motor is dying? especially if it is running 14.1's stock?!
Old Oct 28, 2007 | 04:22 PM
I hear a ticking noise sound waterpump area , weird noise almost like a lifter noise car was running great a few days ago I filled it up and ever since that the noise began I sounds like when you put cheap gas , but i always put super ( maybe bad gas)
car doesnt smoke or anything
Old Oct 28, 2007 | 04:36 PM
oneledvr's Avatar
I assume you meant 180,000 miles? If I was you I would do some more trouble shooting before condeming the engine. Sounds like you are just looking forward to replacing the engine .
I am sure you can make the Impala engine work. However, you may want to consider freshining up your engine. A built 355 would be a good choice.
Old Oct 28, 2007 | 04:45 PM
heres a 2 videos of the noise
http://www.dropshots.com/win98nogood...02-21/06:35:50
http://www.dropshots.com/win98nogood...02-21/06:36:48
Old Oct 28, 2007 | 05:41 PM
Mtxz453's Avatar
yea man i wouldn't replace the engine noise because you hear some clicking. Is the car running any differently since the noise started? When was the last time you changed your oil? My friend had that noise coming from one of the heads in his jeep and he ran some sea foam through there and the noise stopped. Sometimes sludge will build up on the rocker and cause a noise like that. Other than that the car looks like its in fine condition.
Old Oct 28, 2007 | 05:48 PM
Ive had the car for 1 month and i have changed the oil every 500 miles only cause i had spare filters and oil . going to go get some seafoam now , should i run it in the gas tank ???
Old Oct 28, 2007 | 05:54 PM
Mtxz453's Avatar
yea you can you might as well since you'll have it.. but make sure you pour about 1/2 pint into the crankcase and let it run. Here is the link to their website actually they have all the directions and info in there http://www.seafoamsales.com/motorTuneUpTechGas.htm.
Also changing your oil that much can eventually have a negative effect on the engine, you should only changed it around 3000 or even a little more. Every time you change your oil and then start it up, there is no oil circulating through the oil system yet so you get a dry start. Eventually it will take its toll of the wearing of your bearings etc.
Old Oct 28, 2007 | 06:02 PM
cehan's Avatar
I wouldn't be pouring any sludge loosening additives in any engine, let alone one with 180K miles. Some of that crap might loosen up and plug an oil passage to a bearing.
Old Oct 28, 2007 | 08:09 PM
heres a video of it
http://videos.streetfire.net/video/e...d5015b4639.htm
http://videos.streetfire.net/video/2...d5015e1574.htm
Old Oct 28, 2007 | 09:07 PM
oneledvr's Avatar
From the video it doesn't sound like valve train. In fact, the noise seems to vary. It almost sounds like an exhaust leak. Make sure all of the vacuum lines, and intake elbow are tight. To futher isolate the noise, try taking a real long extension or screwdriver and place it on various componets with the other end in your ear. You would be suprised how it works.
BTW, great looking car!!
Old Oct 28, 2007 | 09:14 PM
I did the screwdriver near the alternator, vavle covers and everything sounded good , tomorrow I will take the belt off and try to start it , maybe a bad smog pump or belt tensioner, I didnt want to risk sticking that long screwdriver in there while the car was on
Old Oct 29, 2007 | 12:34 AM
DrewHMS97SS's Avatar
the smog pump is electric, so the belt being off wont help you there. Could be the air conditioning.
Old Oct 29, 2007 | 12:35 AM
Gun5's Avatar
what the hell is the smog pump
j/k
Old Oct 29, 2007 | 12:37 AM
j/k
That thing that gets thrown away, along with its crappy tube...
