My car is nearing completion for track time again, so much changed this year...
Old Mar 5, 2007 | 11:47 AM
  #46
Javier97Z28's Avatar
Moderator
Yah, I've run my car open header before also, never had a problem. That's why I don't think that's the problem.
I can't see my O2's freaking out causing the issue.
Old Mar 5, 2007 | 11:49 AM
  #47
Z-RATED94's Avatar
OK, it was just a thought, and I guess not much of one at that.
Old Mar 5, 2007 | 12:19 PM
  #48
reamo04's Avatar
i have heard of 02's going bad with open headers if you do not have around 18" of pipe on ur headers after the 02's, so it still would be something that is easy to check i guess.
also, running ur package, i would find a place to do a dyno tune
Old Mar 5, 2007 | 02:26 PM
  #49
2000GTP's Avatar
With open headers, the 02 sensors are very close to the outside elements. Incoming air can possibly effect the readings on the 02 sensors creating some buggy drivability issues.
Old Mar 5, 2007 | 02:40 PM
  #50
Moderator
I've debated disconnecting the O2's to see what happens. I might try that tomorrow, just to see.
It's BAD though. The car is bucking wildly at part throttle.
Old Mar 5, 2007 | 03:49 PM
  #51
speed_demon24's Avatar
If you disconnect htem make sure to reset the pcm too or it will go back to the stored data that made the car run so bad. And I ran open headers for ~40 miles and it drove exactly the same as it did with an exhaust on it, so I don't see it being the problem either.
Old Mar 5, 2007 | 03:57 PM
  #52
Moderator
Cool, will do
Old Mar 6, 2007 | 06:37 AM
  #53
cehan's Avatar
Javier, won't just unplugging the MAF and then starting the car keep it in open loop (thereby ignoring any O2 sensor feedback)?
Old Mar 6, 2007 | 07:06 AM
  #54
Moderator
I tried unplugging the MAF, but it didn't make any difference.
Maybe what Rob (speedemon24) said also applies to the MAF, you need to reset the PCM to get rid of the stored values?
Old Mar 6, 2007 | 08:14 AM
  #55
T/A lt1's Avatar
Looks like there are quite a few of us that will be running new LT1 setups this season. I swapped to LE3 LT1 heads/cam (solid roller) T&D shaftmount rockers, Canton oiplan, BMR front suspension, BMR torquearm and a Moser 12bolt. I am in the middle of putting all these parts together and should be running in the next couple weeks. Later Clint
Old Mar 6, 2007 | 12:23 PM
  #56
I've always wanted to see some LE heads with a solid roller behind them, that should make for a sick combo. Keep us up to date on it. On the otherhand I'm waiting for my LE2's to get back, so I guess I might count as someone with a a new combo.
Old Mar 6, 2007 | 10:14 PM
  #57
Moderator
Just an update, I unplugged my O2's today and reset my PCM... and the car ran PERFECT.
Guess Bryan was right, the problem was the O2's being so close to the open header. Maybe it's "ok" for some cars, but not "ok" for others.. who knows.
I figure when I get my exhaust back on the car I'll also get new O2's, as these are probably fouled out now and no good anyways. Runs so well kinda makes you just want to get rid of 'em lol.
I'm still following Yank's 150 mile torque converter break in... so no WOT driving, but I gave it a little more throttle today and goddamn does this car pull hard.. even at less than 1/2 throttle.
I think I'm in LOVE with this Yank No lockup problems either.
Old Mar 7, 2007 | 09:57 AM
  #58
Z-RATED94's Avatar
So my GUESS was correct then. Just messing with ya, the only reason I mentioned it was I read it here. It's nice to have this site, isn't it? I know I'd be lost without it.
Old Mar 7, 2007 | 10:33 AM
  #59
Moderator
Tru, thanks
Old Mar 7, 2007 | 10:50 AM
  #60
Colin91Z's Avatar
Good to hear it's running better now, I look forward to seeing your track times
Did you ever end up deleting your EVAP stuff?
