My car is nearing completion for track time again, so much changed this year...
also, running ur package, i would find a place to do a dyno tune
If you disconnect htem make sure to reset the pcm too or it will go back to the stored data that made the car run so bad. And I ran open headers for ~40 miles and it drove exactly the same as it did with an exhaust on it, so I don't see it being the problem either.
Looks like there are quite a few of us that will be running new LT1 setups this season. I swapped to LE3 LT1 heads/cam (solid roller) T&D shaftmount rockers, Canton oiplan, BMR front suspension, BMR torquearm and a Moser 12bolt. I am in the middle of putting all these parts together and should be running in the next couple weeks. Later Clint
Just an update, I unplugged my O2's today and reset my PCM... and the car ran PERFECT.
Guess Bryan was right, the problem was the O2's being so close to the open header. Maybe it's "ok" for some cars, but not "ok" for others.. who knows.
I figure when I get my exhaust back on the car I'll also get new O2's, as these are probably fouled out now and no good anyways. Runs so well kinda makes you just want to get rid of 'em lol.
I'm still following Yank's 150 mile torque converter break in... so no WOT driving, but I gave it a little more throttle today and goddamn does this car pull hard.. even at less than 1/2 throttle.
I think I'm in LOVE with this Yank
No lockup problems either.
Did you ever end up deleting your EVAP stuff?
