My car is barking at me
Old Jan 31, 2006 | 02:34 PM
zpastor's Avatar
When I first crank my 97 Z is makes a quick barking sound. I suspect it might be related to the belt tensioner or in the clutch. Anybody had this problem?
Old Jan 31, 2006 | 05:49 PM
OBE1 95Z28's Avatar
Re: My car is barking at me
Bark or chirp? If it's a chirp it could be your starter pinion gear binding on the ring gear. Shimming the start will fix this.
Old Feb 1, 2006 | 07:23 PM
zpastor's Avatar
I should have given you more info. It is more of a bark that only occurs when the car is cold, but it does happen for a few minutes, not just in the starting mode. Today I noticed that I can feel something in the clutch pedal (vibration) as the noise occurs. Could it be a clutch fork that needs lubrication?
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
