My car backfires at low rpms!
Old Apr 25, 2003 | 05:58 PM
  #16
Rodrigues's Avatar
I re adjusted the valves while the car was idling, I loaded the stock program as well and that just made it worse. It cant be the o2 sensors because it does it in open loop as well. ZSlates, do you think it was your wires or plugs?
Old Apr 26, 2003 | 08:59 AM
  #17
Timberwolf's Avatar
I think what you should do is just guess and poke around replacing random stuff until you have spent another several hundred dollars on the car and still have the problem rather than just taking it to dsw or somewhere similar and getting it fixed...
Old Apr 26, 2003 | 05:55 PM
  #18
Rodrigues's Avatar
Well I would like to get some opinions first! I really don't like taking my stuff to a shop, I just got laid off for a couple weeks and I am tight on money.
Old Apr 26, 2003 | 07:05 PM
  #19
Rodrigues's Avatar
New spark plugs didnt do anything. I dont even get a PCM code for my rich and lean conditions I don't think the PCM will even allow both, a rich and a lean code.
Old Apr 26, 2003 | 07:20 PM
  #20
Rodrigues's Avatar
Those arent backfires really. Most stock cars do that... My car will make a loud bang and an echo... Im worried im going to blow something apart in my exhaust.
When I press the gas a bit near 1500 rpm's it will backfire consistantly about ever 1 second. It sounds horrible, like a firecracker in the exhaust.
Originally posted by ThotYouKnew
Well...im not really sure about your problem, but when my car is still warmin up and i try to shift around 3 K i get a pop from the exhaust but then once it is warm the pops go away. Also, when i rev up i get a lot of popping. I think i need new plugs and wires...
http://www.ccurtis.net/cz28/media/magna1.wav
http://www.ccurtis.net/cz28/media/magna2.wav
by the way...that site is not mine and doesnt have anything on it of mine other than these clips that maserati82 hosted for me
good luck with solving the problems
Old Apr 26, 2003 | 08:08 PM
  #21
badass383's Avatar
Did this thing ever run right since you installed the cam?
Old Apr 26, 2003 | 08:09 PM
  #22
Rodrigues's Avatar
nope . My opti bearing originally broke from the cam dowel and my headers were glowing, but a new opti fixed that. Before the bearing broke I was still getting the split blm's but I dont recall it backfiring.
Old Apr 27, 2003 | 01:07 PM
  #23
ThotYouKnew's Avatar
Rodrigues
yea, i didnt really think it was bad or anything but those are only revs to like 2500-3000 if i hit like 4500 it pops like a fire cracker and sounds horrible but it doesnt seem to be as bad as the problems on this thread, so i dont feel like i have much to worry about....got 27 mpg on the highway today after drivin up to kent state in ohio to visit my bro...good luck to the guys having troubles tho
97SSdude
Dec 31, 2014 07:43 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
