My C5 CAI works!
My C5 CAI works!
I had this crazy idea about using a c5 airbridge for a intake for the lt1. Well after a little fabrication it appears to be a success. I can't run the car for a nother week but here are a couple pics. The third pic you can see the filter but the pic is crappy and the camera was wiggin out. I do need some suggestions on what to use to put between the cut radiator shroud and the intake to make it look a little better. please excuse the nasty engine bay
Let me know what you think!
http://community.webshots.com/user/kbahus
I have the 1le a/c delete so no ac condensor. The K&N filter i used is pretty large and fit perfectly. There is about 1 inch between the filter and the radiator. I am gonna make a plastic shroud to seperate it a little.
Doesn't look too bad. Could be worse. I imagined it would make the intake look like it had a big ***** hanging down from it, but you successfully made that setup work w/o doing that. LOL. So good job. Very creative.
That is the maf sensor that you see! I had to notch the frame to get it to fit nice and have a maft and used the wires for the extension. Casper Electronics sells maf harness extensions for $20 bucks if you don't have a maft.
The car has been sitting since October and the hose doesn't reach that far but it will be running soon so i can wash her up
I want to get a smooth bellows for it as well as some kind of grommet for the jagged edge. I added a couple more pics.
