My C5 CAI works!
Old Feb 24, 2004 | 11:03 PM
  #16
94-3.4's Avatar
I figured it can't be much worse than a ls1 with ftra, so long as the car is moving it will be getting fresh air.
Old Feb 25, 2004 | 09:40 AM
  #17
AxeGrinder30thZ's Avatar
Originally posted by Seal
wonder how much of a gain ure getting out of that?
I'd say a good 150-175 hp gain. Supercharger effect. [/rice answer]
Old Feb 25, 2004 | 09:51 AM
  #18
93Z286Speed's Avatar
thats probly 150-175 hp at idle
Old Feb 25, 2004 | 10:55 AM
  #19
So probably what...a 350-400 hp gain at WOT? Sounds about right.
Old Feb 25, 2004 | 11:13 AM
  #20
red_warrior_z28's Avatar
what filter did you use (part #) and how much did you pay for that C5 intake. it looks pretty good. i was actually thinking of doing this myself about a month ago, but didnt know what filter to use mine looks a little to big to fit in there.
let us know how much hp you gain or lose from this setup, as soon as you run it.
Old Feb 25, 2004 | 11:14 AM
  #21
scoobysnax83's Avatar
Why is the vette logo upsidedown? I can't picture what it looks like on a C5 so, I'm a little stumped.
If you could shave that logo off, then it would look a ton better as well. I like that setup a lot!
Old Feb 25, 2004 | 11:24 AM
  #22
It would be awesome if he could get the Vette logo shaved off and have the Z28 logo etched in place. That would look sharp!
Old Feb 25, 2004 | 11:54 AM
  #23
Gripenfelter's Avatar
I'd be curious to see how it compares to a regular CAI on the dyno.
Old Feb 25, 2004 | 11:56 AM
  #24
You probably wouldn't see much on the dyno due to the radiator heat, unless you had a serious cooling fan. But on the open road I guarantee its better... Comparable to a Ram Air hood on the new TAs...
Edit: One other thing you need to worry about is the location of the IAT sensor. That needs to be relocated closer to the TB to prevent it from picking up the radiator heat as well.
Only problem with this project is separating it from the radiator heat. Not a huge problem, but a problem none the less.
Old Feb 25, 2004 | 12:05 PM
  #25
americanmusscle's Avatar
Nice idea. Now you can sell it on ebay
Old Feb 25, 2004 | 12:44 PM
  #26
yea, you can charge like a buck 50 and people will pay for it. Stupid ebayers
Old Feb 25, 2004 | 01:28 PM
  #27
Red96Lt1's Avatar
Looks good, also looks like you're missing a drivers side valve cover bolt.
Old Feb 25, 2004 | 01:38 PM
  #28
IslandZ's Avatar
Prolly cause he has OVC wires and has them removed for the pictures, you can see the wires dangling on the right.
Old Feb 25, 2004 | 01:40 PM
  #29
94-3.4's Avatar
Thanks for all the compliments guys.
The iat sensor goes on the drivers side about 4 inches infront of the tb. There was a hole from the c5 one and the lt1 sensor fit with a grommet. You should be able to see it from the pics. There is even a convienent hole for the opti vent tube as well.
I will have to look up the pn for the filter but it is a 7" long, 4 5/8" diameter conical filter that fits right on the maf.
I don't really like that vette logo either, i might try to shave it off one day but would fear breaking through cause it is molded into the intake. I paid $30 bucks for the c5 intake and bellows btw.
alex5366
Feb 17, 2015 09:07 AM
ModdedNerd
Feb 5, 2015 04:37 AM
Cam's maro
Jan 30, 2015 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
