My C5 CAI works!
Old Feb 24, 2004 | 07:16 PM
94-3.4's Avatar
My C5 CAI works!
I had this crazy idea about using a c5 airbridge for a intake for the lt1. Well after a little fabrication it appears to be a success. I can't run the car for a nother week but here are a couple pics. The third pic you can see the filter but the pic is crappy and the camera was wiggin out. I do need some suggestions on what to use to put between the cut radiator shroud and the intake to make it look a little better. please excuse the nasty engine bay
Let me know what you think!
http://community.webshots.com/user/kbahus
Old Feb 24, 2004 | 07:19 PM
JoeliusZ28's Avatar
Thumbs up
I was always wondering why they didnt just stick an air filter on the front of the thing, rather than making a 90 and extending it a ways.
Spinner's Avatar
Looks okay, but how are you going to squeeze a filter down there, and what about the condensor?
Old Feb 24, 2004 | 07:20 PM
Rodrigues's Avatar
My only concern is it picking up the heat from the radiator.
Old Feb 24, 2004 | 07:28 PM
94-3.4's Avatar
I have the 1le a/c delete so no ac condensor. The K&N filter i used is pretty large and fit perfectly. There is about 1 inch between the filter and the radiator. I am gonna make a plastic shroud to seperate it a little.
Old Feb 24, 2004 | 07:30 PM
teke184's Avatar
where is the maf sensor?
and honestly...i think the standard cai looks ALOT cleaner.
Old Feb 24, 2004 | 07:33 PM
94-3.4's Avatar
Let me run outside and take a different pic, that first one sucks.
Old Feb 24, 2004 | 07:36 PM
AxeGrinder30thZ's Avatar
Doesn't look too bad. Could be worse. I imagined it would make the intake look like it had a big ***** hanging down from it, but you successfully made that setup work w/o doing that. LOL. So good job. Very creative.
Old Feb 24, 2004 | 07:45 PM
ibanez6rg's Avatar
Doesn't look too bad. Putting a rubber gromet around the radiator shroud would make it look a TON better. Kind of a choppy cut.
Old Feb 24, 2004 | 07:51 PM
94-3.4's Avatar
The dremel got a little out of hand I want to get a smooth bellows for it as well as some kind of grommet for the jagged edge. I added a couple more pics.
Old Feb 24, 2004 | 07:53 PM
93Z286Speed's Avatar
i like it! anyone ever use the C4 CAI that SLP has? looks pretty cool IMO
Old Feb 24, 2004 | 08:26 PM
Fastbird93's Avatar
Looks good, I like how you cut the shroud around it.
On another note, you need to hit that engine bay with some Simple Green or something.
Old Feb 24, 2004 | 09:29 PM
94-3.4's Avatar
That is the maf sensor that you see! I had to notch the frame to get it to fit nice and have a maft and used the wires for the extension. Casper Electronics sells maf harness extensions for $20 bucks if you don't have a maft.
The car has been sitting since October and the hose doesn't reach that far but it will be running soon so i can wash her up
Old Feb 24, 2004 | 09:45 PM
Seal's Avatar
wonder how much of a gain ure getting out of that?
Old Feb 24, 2004 | 10:21 PM
jasons93z's Avatar
Same or less than a regular CAI. The heat is a bad thing is what im thinking.
