My Big Mistake
Old Jun 8, 2008 | 09:29 AM
  #31
MTBSully's Avatar
Originally Posted by shoebox
You have to adjust them the way the procedure you choose states. You will need an intial adjustment, so method 1 or 3 may be the easiest place to start.
i think im going to go with method #3. No i did not bring #1 to tdc when i began
As far as cleaning is concerned. I took a razor blade to the head and block, then wiped it down good with some brake cleaner. I should be good to gbo right? I might just clean the cylinder and heads with some compressed air to make sure there is no crap there.
Old Jun 8, 2008 | 10:16 AM
  #32
Compressed air, shop vac, whatever gets rid of the crud. Surfaces should be clean of any gasket material, smooth and oil/grease free.
Old Jun 8, 2008 | 11:38 AM
  #33
Pontiac_97's Avatar
well it would have made your life a little easier. you could have really got that piston exactly at TDC with the head off and get almost dead on with the rocker adjustments. now your probably going to have to turn the motor 1 to 2 times to figure out if your at #1 or #6 on the compression stroke.
Old Jun 8, 2008 | 01:44 PM
  #34
MTBSully's Avatar
the head is still off, so i still can. I still have to go look for the arrow that supposidly is on the balancer that will tell me when #1 or #6 is at tdc.
bunker
Jan 30, 2016 08:09 PM
Sep 18, 2015 03:46 PM
NewsBot
Aug 3, 2015 02:40 PM
Louey
Pacific
Jul 27, 2015 09:58 PM
Boss002
Jul 9, 2015 03:33 PM
