Mutherfrikin hoses
Old Apr 18, 2003 | 03:21 PM
el camino ss's Avatar
Mutherfrikin hoses
Well my heater core went tit$ up last night so i figured i would bypass it till my replacement gets here sunday i got a union and everything and i got the clamps off but the sombiaatche hoses wont come off for nothing i even had me and a friend tugging on them at the same time!!!
Anyway i am open to suggesstion on how to get these things off of here i tried twisting them but that didn't work and i am so tempted to cut the damn things off and do away with the heather all together
Sorry for the long post but i wish just one thing on this car would be easy to work on
well thanks in advance
-joe
Old Apr 18, 2003 | 03:48 PM
BUBBA's Avatar
Patience and a length of bent wire to ream around the ends OR if you have plenty of length cut them off. JMHO
Old Apr 18, 2003 | 04:19 PM
GREGG 97Z's Avatar
Re: Mutherfrikin hoses
-joe
Changing the oil is pretty simple, and the fuel filter is very easy to replace. Other than that, yeah pretty much everything else is tough to work on.
Seriously though, I've never messed with the heater core on these cars but I had to fix a leak in one on a pos 85 Cavalier I used to have, and it was a pain the ****. The hose attachment at the core was some cheap plastic fitting and it was molded to the core. I think I had to cut it off or break it off to remove it. You had to replace the whole core to fix it "right", the plastic hose wasn't repairable. I removed that hose and bypassed that section of it with a piece of radiator hose. It worked, but I remember the heat just wasn't as good afterwards I don't know if the setup is the same on 4th gens but I wouldn't be surprised if it was.
Old Apr 18, 2003 | 05:31 PM
grygst76's Avatar
this will sound good---take a pair of vice grips and grab the hose and twist side to side until it breaks free I did that and it works like a charm just don't pull it towards you pull it up and down following the pipe and it will loosen up just clamp the vise down on the hose..
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
