Mutherfrikin hoses
Well my heater core went tit$ up last night so i figured i would bypass it till my replacement gets here sunday i got a union and everything and i got the clamps off but the sombiaatche hoses wont come off for nothing i even had me and a friend tugging on them at the same time!!!
Anyway i am open to suggesstion on how to get these things off of here i tried twisting them but that didn't work and i am so tempted to cut the damn things off and do away with the heather all together:p Sorry for the long post but i wish just one thing on this car would be easy to work on well thanks in advance -joe |
Patience and a length of bent wire to ream around the ends OR if you have plenty of length cut them off. JMHO
Re: Mutherfrikin hoses
Originally posted by el camino ss Sorry for the long post but i wish just one thing on this car would be easy to work on -joe Seriously though, I've never messed with the heater core on these cars but I had to fix a leak in one on a pos 85 Cavalier I used to have, and it was a pain the arse. The hose attachment at the core was some cheap plastic fitting and it was molded to the core. I think I had to cut it off or break it off to remove it. You had to replace the whole core to fix it "right", the plastic hose wasn't repairable. I removed that hose and bypassed that section of it with a piece of radiator hose. It worked, but I remember the heat just wasn't as good afterwards :) I don't know if the setup is the same on 4th gens but I wouldn't be surprised if it was. |
this will sound good---take a pair of vice grips and grab the hose and twist side to side until it breaks free I did that and it works like a charm just don't pull it towards you pull it up and down following the pipe and it will loosen up just clamp the vise down on the hose..
