muffler diamter
muffler diamter
i just got a ultraflow muffler and it 3in in and 3in out lets, the i pipe looks like 3in im wondering if it will be too big of a muffler and if so can the muffler shop down size the pipe on the muffler because i really dont want to send it back?
Stock intermediate pipe is 2.75" and most aftermarkets are 3"
If you are running the stock I-pipe you can still install the 3" muffler. I installed my stock muffler on my brother's 3.4L Camaro. I don't recall his I-pipe size but was a bit on the dinky side
You can pick up reducers but I just slit the inlet to the muffler, use plenty of high temp RTV, and a good band clamp. It sealed up just fine and didn't cost me anything. If you're looking for improved performance I do think the stock, compression bent, I-pipe needs to go.
This isn't really something I'd personally take to a muffler shop... a muffler install's simple!
You can pick up reducers but I just slit the inlet to the muffler, use plenty of high temp RTV, and a good band clamp. It sealed up just fine and didn't cost me anything. If you're looking for improved performance I do think the stock, compression bent, I-pipe needs to go.This isn't really something I'd personally take to a muffler shop... a muffler install's simple!
Originally posted by harley883
HA HA HA ! MUFFLER BEARINGS ALMOST FORGOT ABOUT THOSE,TAKING IT THE MUFFLER SHOP BECAUSE THEY CAN WELD IT UP WITH NO LEAKS THATS WHY
The muffler connections don't have to be completely leak free. Only enough to not make noise. Believe me, there is no danger from fumes if you can't hear the escaping gas and there is no problem with oxygen intrusion behind the cats. The OEM I-pipe (mandrel bent, BTW) has a Torca slip fit that is not leak free, but it is leak free enough to not make noise. You don't need to weld the pipes at the rear unless you want to make sure they never go anywhere. Buttercup has an excellent point about needing to remove the pipes.
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
