To much Hydrocarbons
Old Mar 31, 2004 | 03:51 PM
Evilfrog's Avatar
I failed Emissions, pointing out 1.44 GPM and the standard here is .8 Anyone where i should begin on this?
Old Mar 31, 2004 | 05:04 PM
Are you running a catalytic convertor? If not... that's the likely resaon. If you are, it may be dead. Or you might have an A/F ratio problem.... too rich. In that case unburned HC and CO will generally be high, and NOx will be low. What were the measured levels of CO and NOx, vs. the "standard"?
Old Mar 31, 2004 | 07:39 PM
Evilfrog's Avatar
http://www.freepixhosting.com/upload.../emissions.jpg
Here is the graph
Old Mar 31, 2004 | 10:05 PM
No luck on the link... just times out, even if I cut and paste.
Old Mar 31, 2004 | 11:43 PM
Evilfrog's Avatar
Ok...
Try here.
edit: forgot the link
http://www.fastlouis.com/forums/view...=192571#192571
green93formula
Mar 18, 2006 02:01 AM
92LT1RS
Apr 21, 2004 06:56 PM
Big_Z
3rd Gen / L98 Engine Tech
23
Jun 12, 2003 03:11 PM
