I recieved my new set of MSD's 8.5. I got 9 wires plus 1 for the coil. But all are different lengths. Is it just simple as match to the original length? Where would the longest go?
Quote:
If they are custom fit for LT1s the longest go to the farthest back plugs ie #7 and #8. The passanger side requires slightly more length than the driver's side due to routing around the PS pump. So if custom LT1 wires....match to original length. That easy. I cut and crimped my own Taylor wires so thats as much advice as I can give. HTH and good luck.Originally posted by 1msfyter
also got 2 coil wires with mine... but yeah just match up the lengths, love those little #'s they give you for each wire too...
get some zip ties as they dont fit in the looms...
I also got 2 coil wires.
You don,t mention if you have headers or not.
I have Hooker LTs and for me the two longest ones I used on 5 and 7 cause I ran them over the valve cover and 6 and 8 I ran under the motor mount so they did not need to be as long.
If you don,t have headers then just match up the old wires and replace.
