MSD opti cap & rotor install problems
Old Oct 1, 2009 | 04:41 PM
tim95z28's Avatar
I am having some problems installing this cap & rotor. The kit comes with two screws with washers to install the rotor. If I install the rotor normally, the assembly is very tight and will not spin freely. I then put the two washers under the rotor and it spins freely, but when you put the cap on, there is a noise when it spins.
Are the washers shims, or should they be installed between the screw head and the rotor?
Regarding the seals, there are three, two o-ring types, the third is an o-ring, but square instead of round. Which seal is to be installed where?
Tim
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Injuneer
Dec 15, 2014 09:36 AM
carcrazyQT
Sep 17, 2002 07:54 AM
carcrazyQT
Sep 3, 2002 02:51 PM
