MSD 8.5mm wires.......are they an OVC setup or not?
Old Jun 13, 2003 | 03:36 PM
got_hp?'s Avatar
the msd kit is about $80.
and the taylor OVC kit is $99.
is the MSD (part 32149) and OVC, or stock routing?
how do i get OVC with MSD wires?
Old Jun 13, 2003 | 03:47 PM
GetaZforgetGT's Avatar
MSD-32149 isn't OVC it is for the stock routing position.
I ended up going with the Taylor wires because I had a hard time finding the right MSD kit.
As far as I know the MSD wires come with the opti ends on it.
Old Jun 13, 2003 | 04:00 PM
RacinLT1's Avatar
Summit carries the MSD cut to fit wires with opti ends,i believe the part number ends in 99. The opti ends are pre installed.
You will have to call and have them look through the MSD book,i had a set,but box is long gone.
Old Jun 13, 2003 | 04:23 PM
got_hp?'s Avatar
so i guess im stuck with taylors if i want OVC?
Old Jun 13, 2003 | 05:24 PM
Buttercup's Avatar
MSD P/N 32139 are the cut-to-fit Superconductors with opti ends. I've been using these with R&M looms with good success.
Old Jun 13, 2003 | 07:11 PM
RacinLT1's Avatar
got_hp,the taylor "kit" is a complete setup from Thunder racing.
The MSD's will just be the wires. You can get differetn looms for the MSD's if you want.
So you arent "stuck",you just would have to piece together another setup for the msd wires.
Quickss96
Jan 29, 2016 05:56 PM
canuck94z28
Aug 19, 2015 05:50 PM
detroitmuscle
Jul 31, 2015 04:21 AM
realistyc
Jul 28, 2015 07:32 PM
88IROC_Z
Jul 22, 2015 11:38 PM
