MSD 6al install
Old Nov 27, 2003 | 01:56 AM
1994CamaroZ28's Avatar
MSD 6al install
Got the msd 6al new in the box from ebay and bought the lt1 connector from thunderracing.com, i wanted to see some in detail pictures of how some of you guys mounted yours, and length of time to do install if you guys could, and also any opinions on how the car run afterwords would be cool, i did do a search for this but came up with very little. thanks Ty
Old Nov 27, 2003 | 02:06 AM
Shelldust's Avatar
Id also like to know more about this, I dont have a MSD box but I may get one at some point.
Old Nov 27, 2003 | 02:10 AM
madwolf's Avatar
I mounted mine on top of the triangular plastic piece right under the air filter. Here's a picture.
Old Nov 27, 2003 | 02:26 AM
Heatmaker's Avatar
Advanced Member
You need the blaster coil for it. Don't forget it. The overall box is easy to hookup. Limited room under the hood. Everyone usually puts it next to the Fuse box. THe hardest part of the MSD install is the MSD Blaster coil. You'll have to modify the stock coil brackets a bit to adapt it to fit the MSD coil. THat' the hardest part. Don't know if they fixed that issue or not. I think I had one of the early LT-1 kits or something.
http://www.thunderracing.com/index.c...ategoryid=1087
Old Nov 27, 2003 | 02:40 AM
what do you mean have to have blaster coil it wont work with the stock coil?
Old Nov 27, 2003 | 03:14 AM
madwolf's Avatar
It will work with the stock coil without any problems.....as long as the coil is good.
Old Nov 27, 2003 | 03:49 AM
atljar's Avatar
Heres mine. Must copy and paste link, or you can view it if you go to my website, its linked in the mods section.
http://geocities.com/atljar2002/637879-R1-22A.jpg
Old Nov 27, 2003 | 10:04 AM
ZyberMunster's Avatar
Mine
Laterzzz...
Old Nov 27, 2003 | 11:33 AM
ibanez6rg's Avatar
Here's my digital 6 mounted.
Old Nov 27, 2003 | 11:46 AM
Heatmaker's Avatar
Advanced Member
It can work with the stock coil but your suppossed to use the MSD Blaster coil with it. It's the complete system to get the best performance out the little box. The coils only like 39 bucks or so and a good investment. Having the just box without the coil is like driving a car with no steering wheel. It defeats the purpose of having it in the first place.
Old Nov 27, 2003 | 12:09 PM
ibanez6rg's Avatar
More like having a steering wheel w/o a horn. It's nice to have it but not necessary. Stock coil will be fine as long as its in good working condition.
Old Nov 27, 2003 | 01:17 PM
Compstall's Avatar
The stock coil is JUST FINE with the 6AL, as mentioned.
Here's a pic of my install:
6AL Install
Nov 18, 2023 07:21 PM
Killer94z
Jan 13, 2015 12:06 PM
thenewkid
Nov 27, 2014 09:41 AM
