mounts
Old Jul 6, 2007 | 01:41 PM
lt1loudmouth07
Guest
Posts: n/a
mounts
Ok guys i bought the engery suspension mount at advance auto parts for my transmission, And i just replaced the motor mount on the passanger side with a rubber one the old one was broken in two, now when i punch it it feels like the trany is going to come through the floorboard, Do i need to hack the trany mount down alittle and by the way i do not have the plate on the trany mount i did not put that on. how do i align the pinion angle up with the rearend
95 camaro z28
Longtube headers
30lb Injectors
Stock motor
90,000 miles on it
Old Jul 6, 2007 | 03:48 PM
Seems odd.... with my M6, the ES mount held the tranny rock solid, eliminating the bouncing shifter. I used the metal plate.
To adjust the pinion angle, you need an adjustable aftermarket torque arm.
Old Jul 6, 2007 | 04:15 PM
Don 97 SS's Avatar
I would think you should replace both engine mounts as a set and not just one. Having one new and one highly aged rubber engine mount may contribute to the problems you are experiencing.
Old Jul 6, 2007 | 06:32 PM
NemesisLT1's Avatar
so the energy suspenion tranny mounts work good on 4l60e's or do they need to be gapped like they do on v6 models?
G-BODYT56
Jan 14, 2022 11:14 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
War Engine
Sep 18, 2015 07:28 PM
Daluchman1974
Sep 11, 2015 06:12 AM
