mounting optispark on conventional distributor shaft
has anyone over thought of mounting an optispark to a conventional distributor shaft to use an obd1 or 2 lt1 pcm on an older SB or BB for true SFI?
Re: mounting optispark on conventional distributor shaft
its quite large so that may make clearance issues, but true SFI for older motors costs hella $$$ with custom crank/cam triggers and such. or.. someone could just modify a 95+ opto cover and cut the waterpump section off and make a sealing surface like the older style timing chain cover? and just use the pump drive gear like our LT1s.
The Opti-Spark was moved to the front of the cam so the cam-to-distributor gearing clearance would not add to "scatter."
Since the high-res pulse of the Opti-Spark is supposed to have 1 crankshaft degree of accuracy, I wonder how it will be affected by the extra gear clearance. However, I would think a worn timing set would also affect it. But, a worn timing set and cam-to-distributor gear clearance would be even more.
Tom Piper
Tom Piper
all that would be needed is an indication to line up #1 tdc. I'm not sure where the dowel or key is in relation to the rotor.. I never payed much attention to that but that would be a small hurdle. it is possible that a small amount of "slack" could be taken out by manually clocking the distributor.. even if there was a small amount of scatter, I think the gains of a fully programmable fairly inexpensiveSFI to an older motor would outweigh the loss in precision of a degree or two of timing.
Victor Lamb
Aug 26, 2017 02:52 PM
